Spacers
Old Dec 1, 2006 | 08:18 PM
Shogunsc4's Avatar
Spacers
Which spacers would make my rear wheels most flush with the body without rubbing issues? I have SSR-C 18X8.5 with 42mm offset running on 255/40/18 tires.
10mm or 5mm?
Old Dec 2, 2006 | 03:12 PM
Ammi's Avatar
350 Detroit Muscle
I would say 10mm but the only issue w/ 10mm spacer is that you would have to get longer studs which means more work.
Old Dec 2, 2006 | 08:19 PM
DrKlop's Avatar
Driving is the next best thing
5 will be totally fine. In fact, I'm pretty sure that 10mm will cause the wheels to stick out. I know that 8" wide rims with 35mm offset sit flush with the front fender. Your 8.5" wide rims with 42mm offset and 10mm spacers will be approx 9mm further out.
Old Dec 11, 2006 | 02:27 PM
povartrader's Avatar
I'm actually looking for a 20" 245/35/20 tire. I live in San Diego and mostly need great traction and good tread wear. Been considering the Kumho ECSTA SPT, Nexen N3000, Sumitomo HTR ZII, and NITTO 555. What do you guys suggest?
Old Dec 11, 2006 | 07:12 PM
Ammi's Avatar
350 Detroit Muscle
try to stay away from Nittos.
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
