19x9 wheels
Old Dec 2, 2006 | 04:33 PM
NISMOJUNKIE's Avatar
19x9 wheels
Has anybody tried to put a 19x9 wheel on a 2002? Just wondering if it will fit.
A friend has a set with a 45 offset for cheap off his mustang. Wondering if they will fit, and if they will, does it look stupid.
Old Dec 2, 2006 | 04:53 PM
irish44j's Avatar
retired moderator
1. 19x9 will fit, but it might be tight with that offset.
2. It only looks stupid if the wheels are ugly.
Old Dec 2, 2006 | 07:11 PM
hayai240sx's Avatar
It's all about offset and tire size. Could probably fit 10" with fender rolling ...
Old Dec 2, 2006 | 08:05 PM
Nathan's Avatar
In that wheel size & offset, you should be okay, as long as your tires aren't oversized. Especially on the front, you have to watch out it doesn't rub excessively when you turn. The rears should be fine.
Old Dec 3, 2006 | 07:31 AM
Thanx guys, the wheels are ssr 2-piece. I had planned on replacing the the tires with new ones. I was going to use 235/35/19. Let me know what you think?
Old Dec 3, 2006 | 10:48 AM
Nathan's Avatar
I'd honestly go wider, with a 245/35/19, especially since the rims are 9 inches wide.
I have 8.5 inch wide rims & using 245 wide tires. But if you like a slightly stretched look to the tires than a 235 would be nice.
Old Dec 4, 2006 | 09:31 AM
Tommy Boy's Avatar
I'm running 19 x 8.5 38mm backspacing with a 255 wide tire and lowered approximately 1.25-1.5 inches on k-sport coilovers. I have no rubbing issues at all.
Old Dec 28, 2006 | 12:45 PM
Forevermax13's Avatar
I'd honestly with a 245/35/19, alot people say they rubb have you went to tire rack or just call. GOOD LUCK
Old Dec 29, 2006 | 04:13 AM
LeX's Avatar
LeX
Nissan by Nature
definitely 245 35 19, the 235 won't look 'right'
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
