Should I get spacers??
Definitely get 15mm H&R spacers at the rear. It makes a big difference.
My set up is 19x8.5" rims with 245/35/19 tires and S-techs along with 15mm H&R spacers at the rear.
Originally Posted by seshead
wouldn't getting 30 offset rims defeat the prupose of having spacers?
or is better to get 40 offset wheels and spacers? 18 x8 rim BTW
Uhhh, keep in mind the size of spacer than a person can run will ALL depend on several different factors:
- suspension height
- wheel width
- offset
- tire size
So 15mm spacers might work for him, or might not.
I know that G35 wheels, which are pretty flush in the rear stock, are 18x8 30mm offset. If you figure the tire size is the same between that wheel and the 18x8 40mm offset wheel, then 10mm would make it pretty flush. 15mm will bring it out 5mm further.
Maxboy23
Aug 11, 2015 11:59 AM
