enkei rs7
Old Jun 7, 2007 | 10:32 PM
Teufelhunden's Avatar
enkei rs7
i wanted to get the 18" enkei rs7 from edge racing. but they only have 18x7.5. would 235/40/18 be a good size? since it comes with the package. or 225/45/18 would fit nicely? does any one have a pic of 18x7.5 rim on a 235/40/18 tires? i just wanted to see how they look. thanks.
Old Jun 8, 2007 | 02:42 AM
MorpheusZero's Avatar
235/40 should be alright on a 7.5J rim (235/45s are slightly stretched outwards on a the stock 17*7J). However your rolling diameter will be slightly lower.
Old Jun 8, 2007 | 03:26 AM
LS_TurboEG's Avatar
I like those wheels.!
Old Jun 8, 2007 | 03:46 AM
If I were you I'd go for some 18*8.5J or 18*9J RPF1s...
Bit more $ though.
Old Jun 8, 2007 | 07:34 AM
absoundlab
i have 18 x 7.5 inch rims with 245/40/18 on them
Old Jun 8, 2007 | 09:06 AM
could you post a pic?
Old Jun 8, 2007 | 09:08 AM
Bit more $ though.
theyre hell of alot more than the rs7 and they weigh 22lbs. the rs7s weigh 19.5 and alot cheaper.
Old Jun 8, 2007 | 12:54 PM
http://wayneswheels2000.com/ENKEI-RPF1.html
You were thinking of the RPF1-type RC (22lbs and $500 apiece). These are about $280 shipped apiece, plus they come in wider than 7.5J.
7.5J - 17lbs
8J - 18lbs
8.5J - 18.3lbs
Plus they look great if you get 'em in the right offset (so the spokes don't bulge):
Old Jun 8, 2007 | 05:26 PM
z32drifter's Avatar
But the buldge clears BIG brakes...... and 17s are even lighter.
Old Jun 8, 2007 | 05:58 PM
Dood I know what the bulge is good for. He doesn't have big brakes.
Old Jun 8, 2007 | 11:42 PM
7.5J - 17lbs
8J - 18lbs
8.5J - 18.3lbs
ah, i didnt know they had different kinds.
im just not feeling the extra lip on the wheels.
Old Jun 9, 2007 | 01:11 AM
Eh, if you don't dig it then what can you do. I thought that was the best part.
Anyway you should be okay with 235/40s on a 7.5J.
Old Jun 9, 2007 | 09:17 AM
they do look hot on the rx-8, but dont know if itll look good on a 5th gen.
Old Jun 10, 2007 | 04:38 AM
Looks pretty good to me.
These are IIRC 9J front and 9.5J rear. Car is Larrio's.
Old Jun 10, 2007 | 10:14 AM
^^^ those are 18s? they def look better with out the bulge. would you know the offset on those? i was thinking 18x8.5 with 30mm offset.
Old Jun 10, 2007 | 02:35 PM
I think he said those had to be special ordered, but they were both in the +3x offset range.
Keep in mind Z32drifter's fronts with the bulge are 17x8.5 +40. You'd be taking a bit of a gamble if you got 18x8.5 +30 IMO. If I were you I'd either try and get ahold of a distributor and ask them about that specific wheel, or see if I could find some pictures of the 18x8.5 +30 on a car somewhere.
Old Jun 10, 2007 | 03:05 PM
well the 18" g35 wheels are 18x8 with 30mm offset and they look perfect on the 5th gen. would 18x8.5 30mm stick out too much? edge racing has a 18x8 with 35mm offset, but it seems like it still has a little bulge on them.
Old Jun 10, 2007 | 03:46 PM
They'd stick out a tiny bit, but you're not going to notice the extra 1/4" of protrusion/front spacing. I'd be more worried about clearance than looks.
Old Jun 10, 2007 | 03:53 PM
clearance? you mean breaks or sticking out of the wheel well? so i guess the safest is to go 18x8 with 35mm huh?
Old Jun 10, 2007 | 04:31 PM
I mean more about them scraping your fenders if you're lowered.
If you don't want the bulge I wouldn't go below an 8.5J though.
Old Jun 10, 2007 | 04:38 PM
i see what your saying. if 18x8 with 30mm dont scrape, i think 18x8.5 with 30mm wouldnt either, but not for sure. most likely i probably go with 235/40/18 tires.
edit: ok i just did the offset calculator and the wheels will stick out 34mm. in inches its roughly 1.3 inches. i just read someone running 19x8.5 with 35mm offset and do not rub.
MAXSE5SPD
Aug 23, 2015 12:06 PM
BlkCat
Mar 21, 2002 08:38 AM
97BlackMax
Jan 29, 2002 07:05 PM
soundmike
Jan 17, 2002 11:57 PM
metallic97gxe
Oct 23, 2000 02:04 PM
