17 X 9 with a 27mm offset will it fit a 4th gen?
Old Jun 13, 2007 | 07:07 AM
97SEdriver's Avatar
this place is dead
there's a local guy with these lightweight nice rims, good price, anyone know if these will fit.
I can take measurements, but I'm more wondering if it's been done or not.
Old Jun 13, 2007 | 07:35 AM
Puppetmaster's Avatar
They'll likely stick out some. You can probably check how much using the wheel/tire calc in the Stickies.
OT, and I know you already know this, but > 8" wide rims will take you out of STS, STX and into SP or SM wouldn't it?
Not to say you can't handle it or anything....
Old Jun 13, 2007 | 08:03 AM
MorpheusZero's Avatar
They'll fit, but they're going to stick out quite noticeably (probably about an inch). What are they?
Old Jun 13, 2007 | 08:24 AM
97SEdriver's Avatar
this place is dead
you forget...I am not a rule follower like Irish...I will continue to say I'm GS until someone says something.'
"If you ain't cheatin' you ain't tryin"
Old Jun 13, 2007 | 08:26 AM
97SEdriver's Avatar
this place is dead
I think they're weapons, I can't find the original email from this guy anymore, I must have accidently deleted it.
A little fender rolling can probably go a long way.......
Old Jun 13, 2007 | 09:16 AM
Chunger's Avatar
My other car is a Hybrid
I rub quite a bit with my 35ET with 245/45/18's so you won't be able to get away with rubbing on the front fenders on dips (rear fender lip will require cutting)... unless you have very limited suspension travel...
Old Jun 13, 2007 | 09:34 AM
ewuzh's Avatar
I was thinking about getting a set of them too because of their low price and aggressive offsets. If you're paying more than 400 for a used set, you are paying too much. I was planning on going with 17x9 +17 in rear and +27 in front. You WILL need to roll your rear fenders and assuming you go with +27 all around, you may be able run a 255 tire in the rear and not rub. My 17x9 +34 w/255's have a tiny bit of room left. Front will need to run a smaller tire with some negative camber to get it underneath the fenders.
Old Jun 13, 2007 | 12:02 PM
97SEdriver's Avatar
this place is dead
I think the price was 425-450, again, I stupidly deleted the email.
Old Jun 13, 2007 | 07:43 PM
20lbs for a 17x9J isn't too light. I'd look into Falken Hanabis if I were you. They're a little more but should be lighter.
Old Jun 15, 2007 | 07:50 PM
z32drifter's Avatar
Here's a 17x9 +34 with a 255/40 it sticks out but never rubbed. They did rub in the rear over high speed dips... trim or roll rear fenders. A +27 is going to be out another 7mm ... I'd pass on that set.
Old Jun 15, 2007 | 11:01 PM
Get 'em, then get some 25mm spacers and run a 185-section tire.
Old Jun 19, 2007 | 08:49 AM
97SEdriver's Avatar
this place is dead
now that was a very useful post...thanks....
MAXSE5SPD
Sep 17, 2022 04:00 AM
Wareagle92
Sep 3, 2015 07:18 PM
Lowered_a33
Sep 1, 2015 07:49 PM
