question about 18 x 9.5 all the way around
Old Sep 25, 2007 | 09:53 PM
absoundlab
im looking at getting sportmax 962 rims.
they sell a package 18 x 8.5 with a 2 inch lip 35mm offset in the front
18 x 9.5 3 inch lip 35mm offset in the rear
I dont want a 2 inch lip in the front. I want to match it up with a 3 inch lip all the way around. which would mean I have to run 18 x 9.5 all the way around.
on a 5th gen is 18 x 9.5 in the front too wide? is there anyway that this could work?
http://www.sportmaxwheel.com/sportmax_962.shtml
Old Sep 25, 2007 | 11:37 PM
MaxBoost925's Avatar
Drug Money
dude i told you it would work. Just roll the rear fenders.
You'd have to use 225 width tires though.
Old Sep 26, 2007 | 05:03 AM
LeX's Avatar
LeX
Nissan by Nature
you wouldn't need to roll the rear fenders running 225 .. I run 18x9.5 38offfset with 265 tires and coilovers and no rub in the back
Old Sep 26, 2007 | 08:31 AM
absoundlab
im more worried about the front. will the 18 x 9.5 be too wide for the front.
Old Sep 26, 2007 | 12:30 PM
LeX's Avatar
LeX
Nissan by Nature
I ran a 19x8.5 in the front , 35 offset with 235 tires and I had a good bit of space, it is possible that you wouldn't have an issue but it would be really close... you could try it with 245 rubber and a bit of camber and you would probably be alright but depends on how much you're dropped!
Old Sep 28, 2007 | 05:38 PM
VIP Maxima
225 on 9.5" will look ugly. that will leave a lot of rim on both sides of the tires with nothing wrapped around it.
Old Sep 28, 2007 | 07:50 PM
MorpheusZero's Avatar
Check out maxboost925, he's running 215s on a 9" rim. 225s on a 9.5" would have a very similar stretch, albiet more so since 1/2" > 10mm, and because your sidewalls will be shorter.
Old Sep 29, 2007 | 10:52 AM
absoundlab
I was thinking of using a 245/40/18 on the 18 x 9.5 rims
Old Sep 29, 2007 | 11:51 AM
Fast1one's Avatar
You will probably rub under full compression in the rear with 245s, just roll your fenders in the rear...
You should be fine in the front, I run those sizes on a fourth gen http://forums.maxima.org/showthread.php?t=537165. No rubbing under full lock, may rub under compression and full lock but it hasnt yet...I will stick out in the front about 15mm though...
Good luck finding the 962s. They were on national back order last time I checked...Only ones I have seen are crappy widths...
Edit: This is all based on a fourth gen, I think you may be fine with a 5th gen sorry
Old Sep 29, 2007 | 02:21 PM
absoundlab
maxboost told me i would need 15mm in the front and 20mm spacers in the rear. he also said the bore on the sportmax 962 are for a 240 and wont match up to the 5th gen. I know he was running 300zx calipers so idk if i'll need those spacers that he was using
Old Sep 30, 2007 | 11:05 AM
BLACKonBLACK98's Avatar
Former Vendor
i would do some measuring. what fits to one person might not be what your looking for. maxboost is into vip styling where rims poking out a good amount is acceptable and tires are stretched to their limits, and fast1one is from the make the car fit the rims school of thought. both are very extreme. no offense you guys, both y'all are doing your thing. unless you're into that style you might want to go a lil more conservative than what those guys perfer. i'm no 5g expert but 9.5 sounds wide to me.
Old Sep 30, 2007 | 11:09 AM
Fast1one's Avatar
Hes running very stretched tires, if you plan on running more than a 225 on the wheel then your not going to want to space it that much....all nissan's have the same hub size so I don't know what he means
Old Sep 30, 2007 | 04:19 PM
absoundlab
well I guess what i'll do is buy the sportmax 962 18 x 9.5 all the way around with 38mm offset and put 245/40/18's on them and see what it looks like and i'll go from there
Old Sep 30, 2007 | 07:14 PM
VIP Maxima
you will rub turning the wheel. those whees are really heavy too
Old Sep 30, 2007 | 07:53 PM
Fast1one's Avatar
I dont rub with those tire sizes
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
