Wheel Stud Question
Wheel Stud Question
Hey guys. I purchased a set of 16" BBS RX rims recently and ran into a bit of trouble when installing. It turns out that the lug holes are so inset into the wheel that my wheel studs do not reach out far enough for me to put lugs on them and tighten down. The studs stick out of the holes about 4-5mm tops when on centered.
My question is what should I do about this (the obvious being to buy new wheel studs) But what size should I buy? I know I need M12-1.25 but as far as length and anything else I am a bit stumped. Thanks in advance...
Nismo makes 52 and 60mm studs. Stock are 42mm if I recall correctly. Those are what you want, or you can spend hours and hours fiddle-fcking around with trying to find some stock studs from another car that have the proper knurl, etc. You can get the nismo studs all over the place. I bought mine from Courtesy I think.
The Frye
Sep 2, 2021 11:03 AM
sdotcarter
Sep 2, 2015 09:53 PM
