4th gen with 19" G35 Rays Tire Suggestions...
Old Nov 4, 2007 | 05:38 PM
99BlackMaxMS's Avatar
I just picked up a set of G35 19" Rays, and the rear Potenzas are completely bald. The front Potenzas still have some life left in them, but I am looking for a good tire to go on the rear. Right now I have stock suspension, but will be lowering between 1.5 and 2.0 inches by spring when I actually put the rims on. Here are a few questions:
1. Will the stock size 245/40/19 rub in the rear when lowered?
2. What size diameter tire do you recommend...245, 255, etc.?
3. What brand?
Thanks in advance.
Matt
Old Nov 4, 2007 | 05:49 PM
maxima985spd
go with a 35 series....how wide are the wheels?
Old Nov 4, 2007 | 05:52 PM
8" up front
8.5" in back
Im looking at cheaping out right now and getting used OEMs with 40% left for about $150. I just dont want to rub when I drop my car.
http://cgi.ebay.com/ebaymotors/2-nic...spagenameZWDVW
Old Nov 4, 2007 | 09:41 PM
maxima985spd
go with 245/35-19 tires. LOL @ rubbing with a stock suspension
Old Nov 5, 2007 | 06:48 AM
BLACKonBLACK98's Avatar
Former Vendor
+ 1 on 245/35. you will probably never rub with an 8.5" factory offset, no matter what.
Old Nov 5, 2007 | 12:01 PM
What about 255/35s? Will i rub from the extra 10mm of rubber?
Old Nov 5, 2007 | 01:18 PM
96blkonblkse's Avatar
theres no need to go so wide in the rear unless you are going purely for looks. 245/35/19 is a good size for you. 255 may cause you to rub, because that is fairly wide to top it off on a 19" rim.
Old Nov 5, 2007 | 02:25 PM
Only reason why I ask about the 255/35/19 is because I can get a decent set used for a fraction of the price. I can also get the 245/40/19s a a good price too. I haven't dropped the car yet, so I am still clueless as to how badly they can/will rub.
So with that said, 245/40 or 255/35? Im leaning towards the 255/35...
Sorry for all the newb questions...im still new in this field.
Old Nov 5, 2007 | 06:56 PM
MorpheusZero's Avatar
I'd stick with 245/35s, but you can probably squeeze 255/35s on there if they are 8.5" (will be a tight fit though).
245/40 is too tall a tire for a 19", ideally you'd be at like 245/33 but they don't make those.
Old Nov 5, 2007 | 07:27 PM
Only reason why I ask is because I can get 2 Potenza RE050A 255/35/19s for under $200 with 75% treadlife.
Old Nov 5, 2007 | 07:32 PM
NmexMAX's Avatar
dot dot dot ...
Staggered FTL. You MIGHT rub on some severe bumps in the rear after you're lowered. Anyone know the offset of these wheels?
Old Nov 5, 2007 | 07:56 PM
IHAVEA2KMAXIMA's Avatar
get some 245/35/19 and roll ur fenders
Old Nov 5, 2007 | 08:03 PM
Offset is 30mm front, 33mm rear.
The only prob is that 245/35/19s run $200+ each new...
Old Nov 5, 2007 | 08:22 PM
steven88's Avatar
Need A Light?
Gotta pay to play
Old Nov 12, 2007 | 01:00 PM
UPDATE:
I bought 2 245/35/19 Fuzion ZRi's for the rears last night. They will be mated with the stock 225/40/19 Potenza RE050A's in the front. Thanks for the help guys.
Old Nov 24, 2007 | 11:08 PM
maximariceboi's Avatar
just curious..you have any pix with the rims/tires on your 4th gen? trying to see if the front actually sticks out or not. thanks
Old Nov 25, 2007 | 10:09 AM
I put them on the car to see how they would look a few weeks back, and did not like the look, and is why I am selling. You can see in this picture, that the front does stick out a little bit (30mm offset) and the rears are flush (33 offset).
Old Nov 29, 2007 | 08:57 AM
WhiteA32's Avatar
DO you have more pics?
Old Nov 29, 2007 | 12:36 PM
Here yah go...
http://forums.maxima.org/showthread.php?t=543777
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
02nissmax
Sep 5, 2015 01:50 PM
