hubcentric rings
Old Nov 19, 2007 | 10:06 PM
eK9aT10pSi's Avatar
hubcentric rings
what size hubcentric rings do i need for a 6th max to use cobra rotors? the inner bore and outer. thanks.
Old Nov 26, 2007 | 04:31 PM
Jeff92se's Avatar
I'm needing a caw
No one make rings for this. Hubcentric rings are for centering wheels on the hub bore, not centering rotors on the end of the hub. You have to have them made. I've been offering the rings in the past with the BBK brackets.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Pied
Sep 26, 2015 03:29 PM
msellas
Sep 23, 2015 09:16 PM
DBear
Sep 14, 2015 08:33 PM
95Maxi
Aug 25, 2015 08:01 PM
