wheel and lug nuts question/experiences
Old Dec 17, 2007 | 01:29 PM
JOMAN's Avatar
hey guys
i am in the market for some new wheels. i am looking 19x8.5 or 19x8 fronts and 19x9.5 or 19x9 in the rear MMR GT1 wheels.
yes i know staggered for a front wheel drive...
my question is that has anyone had this setup? any issues rubbing? spacers? what type? i just want general info and feedback and neg and positive feedback would be great!
my suspension setup is eibach's with kyb gr2's
thanks in advance guys
Old Dec 17, 2007 | 05:14 PM
Fr33way™'s Avatar
Wild for Width
What are the availible offsets?
Old Dec 17, 2007 | 07:19 PM
Fast1one's Avatar
Originally Posted by JOMAN
hey guys
For the first setup run something around a +25 and +27 offset for the 8 inch and 8.5 inch wheel respectively. Run something like 235s in the front and 245s in the rear...
For the second, Run around a +30 offset for the front, and +35 for the rear, 245s for the front and 255s for the rear...
Just use spacers to compensate if you have to, this is for max flush, you may need to roll your fender in the rear, though its really easy to do...
BTW it would be a lot easier to run a 9 inch wheel with a +35 offset all around, 245s or even 255s and a 10-15mm spacer in the rear...don't be a poser
Old Dec 18, 2007 | 12:46 PM
JOMAN's Avatar
is it possbile to run 9' all around? i thought that wasnot possible...as far as the offset i failed to mention its +45
thank you fast1one for your feed back that really helped! now i'll just go with 19x9's all around!
thanks again!
Old Dec 18, 2007 | 07:47 PM
Fast1one's Avatar
thanks again!
Yup, just run spacers till you are flush, careful though a 9 inch wheel with +45 offset may not clear suspension (though If I remember there is plenty of room). I would get 10mm spacers for the front, 15-20mm for the rear to be safe...
Old Dec 20, 2007 | 10:04 AM
hotstartup's Avatar
whats the stock offset? i wanna get this rims with +50 offset wondering if it'll sit ok/
Old Dec 20, 2007 | 11:44 AM
Fast1one's Avatar
I replied to your thread...
lowpost99
Oct 26, 2025 06:53 PM
camako
Sep 22, 2015 04:27 PM
bumpypickle
Sep 19, 2015 01:07 AM
dcam0326
Sep 8, 2015 11:02 PM
