off set question
Old Feb 4, 2008 | 10:34 AM
xlcrew's Avatar
I’m Back
off set question
ok i have found a set of wheels i would like to buy. they are tsw estoril's i want to get a 17x8 and fit a 235-45 tire on them. for our bolt pattern i have two offsets to choose from it's either a 20mm or 40mm i was just curious which would be the best for our cars. right now i have the G35 17" coupe wheels on and i have the 17x8 in the front and i really like the look with the 33mm off set and i'm not sure if the 40 would be too much or not. any input would be great. here's a pic of the wheels
Old Feb 5, 2008 | 08:09 AM
phatboislim's Avatar
if you got a 40 offset it would sit in more..just an fyi. what are you trying to accomplist
Old Feb 5, 2008 | 08:12 AM
Deckdout2's Avatar
Play with my balls
I already have an offset thread running in the Wheels/Tires section. Might want to check there. Good info.
http://forums.maxima.org/showthread.php?t=552751
Old Feb 5, 2008 | 08:58 AM
NmexMAX's Avatar
dot dot dot ...
In order to be flush on a 5th gen without having to go staggered, you will need spacers that will effectively make your rear offset 20 -25mm, and your fronts about 30mm.
It's discussed in Deckdout2's thread too.
Old Feb 5, 2008 | 10:04 AM
xlcrew's Avatar
I’m Back
thanks for the info guys i'll check it out. i just want them to be flush
pktaske
May 6, 2016 07:49 AM
boomerbrian
Sep 4, 2015 08:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
