Deciding on these rims and tires (opinions)
Old Feb 5, 2008 | 09:21 PM
Maximized2000's Avatar
I'm looking to probably pick up a set of Tork Imagine 18 x 8. I can't decide between black or hyperblack.
Thanks to KyleFort32 for the photoshop work.
Also, I'm deciding between Falken FK 452 or Nitto 555 in 235/40/18. I'm currently running Falken FK 451 and they seem to wear out pretty fast and I could hear a lot of road noise. Heard the 452 were an improvement. Opinions welcomed.
Old Feb 6, 2008 | 12:15 AM
JOMAN's Avatar
i like the hyper black...=)
Old Feb 6, 2008 | 02:30 PM
Silverfox's Avatar
Go with the black. WHen and where did you get that pic taken anyway?
Old Feb 6, 2008 | 02:47 PM
Bborges's Avatar
i liked black, though hyper black also matches your car pretty well because of the lighter color lower body work.
how much $$ and Lbs for these @ 18x8 ?
Old Feb 6, 2008 | 05:50 PM
NmexMAX's Avatar
dot dot dot ...
IMO, 235’s are too narrow for a 5th gen, add a body kit to that, and it’s way too thin. Get wider tires (245’s) and add some spacers in order get your wheels flush with the body.
Old Feb 6, 2008 | 06:38 PM
The date is on the picture. I took that on i95 around the airport area.
Old Feb 6, 2008 | 06:43 PM
Yea....its a tough choice. Right now I'm leaning towards black. I'm currently running 18 inch Voxx Saga's now and they are hyperblack.
The Tork Imagines would run around $1400 with Falken Fk452 tires. I'm not sure how much they weigh but I'm sure they're not that light.
Old Feb 6, 2008 | 06:53 PM
I'm currently running 235s on my 18s now and they are alright. Definitely not flush in the back but its fine up front.
I was considering the Tork Imagines in 18 x 9 but not sure if it would fit right cuz the website I was looking at didn't even list it for a maxima. However, they do make them in that size.
Old Feb 7, 2008 | 08:56 AM
NmexMAX's Avatar
dot dot dot ...
Change the tire size before changing the wheels size. And read my post about spacers if you want flushness w/o going staggered.
Old Feb 9, 2008 | 11:29 PM
Hmmm....maybe going with Axis Reverbs instead now. 18 x 8.5 and its 20lbs.
Old Feb 9, 2008 | 11:51 PM
NmexMAX's Avatar
dot dot dot ...
Still read my post, you need spacers in the rear for flushness.
Old Feb 10, 2008 | 08:12 AM
Gotcha I need spacers in the rear for flushness. What mm?
Old Feb 10, 2008 | 12:04 PM
Fast1one's Avatar
Depends on the wheel and tire. Once you put them on get off your *** and measure Just subtract like 5mm from the edge of the fender so you won't rub...
Old Feb 15, 2008 | 08:53 AM
AXISMAX's Avatar
LIKE THE HYPER BLACK LOOK. THATS THE FINISH ON MY WHEELS. IM ALSO RUNNING ON 452S. NO COMPLAINTS. NOT ALOT OF NOISE. IM SATISFIED WITH THEIR PERFORMANCE.
Old Feb 15, 2008 | 06:43 PM
Thanks for the imput. And thats a sweet max you got there.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
Serotta33
Sep 17, 2015 12:14 PM
adamgalazka
Sep 9, 2015 03:39 PM
