Will 20 rub on my 5th gen
Old Apr 21, 2008 | 04:41 PM
speedstermax's Avatar
I have a fith gen that is lowerd with tein springs I want to put 20 on it I was just wondering if they are going to fit right with out rubbing. The size of the rims are 20 by 8.5 please can some one let me know
Old Apr 29, 2008 | 01:06 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
a little old but you can run 20's on your set up. Just make sure your offset is right. Go with a 35mm offset or so and call it a day. Tires should be around 245/35/20's. Any larger sidewall and you may have issues
Old Apr 30, 2008 | 06:50 PM
NmexMAX's Avatar
dot dot dot ...
The answer to this question depends on the offset.
Old May 6, 2008 | 08:06 PM
ICULookN's Avatar
What about 38mm offset?
Old May 7, 2008 | 11:02 AM
NmexMAX's Avatar
dot dot dot ...
20 x 8.5 +38mm will not rub using a 245.
Old May 7, 2008 | 11:24 AM
MorpheusZero's Avatar
They will rub any good looks or hope of being quick your car had away.
Old May 7, 2008 | 11:26 AM
BLACKonBLACK98's Avatar
Former Vendor
blah blah blah.
Old May 7, 2008 | 11:28 AM
Originally Posted by BLACKonBLACK98
blah blah blah.
How dare you quote me.
Old May 7, 2008 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
on that analogy
Old May 7, 2008 | 11:59 AM
Former Vendor
when quotes attack?
btw, just to clarify, i was "blah blah blah"ing the "big wheels are ugly and make you slow", not the "will these 20s rub" (which deserved a "blah blah blah" of its own).
Old May 7, 2008 | 12:02 PM
when quotes attack?
I know you well enough to know what you were blah blah blahing
Old May 7, 2008 | 12:12 PM
Former Vendor
word... i got 140 lbs of 3 pieced forged 19" goodness showin up in a couple days. maybe you can poop on my parade too.
Old May 7, 2008 | 12:42 PM
I am not sure about your parade, but I will certainly **** in your corn flakes.
Old May 7, 2008 | 12:48 PM
Former Vendor
YUCK!
who eats cornflakes?
Old May 7, 2008 | 01:29 PM
ICULookN's Avatar
Thank you.
Old May 18, 2008 | 09:00 AM
playboi21617's Avatar
mine didnt rub until i lowered it on H&R 1.4 in the front, when i turn the wheel. other than that its coo it looks so much better
MAXSE5SPD
Sep 17, 2022 04:00 AM
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
