Question about Transmission and Wrong sized tired
Old Apr 21, 2008 | 06:31 PM
WhiteA32's Avatar
So some of you may know that I have 350z wheels on my car along with Z tires. They are staggered.
So I am an auto and since I put the tires on my car's transmission has been acting funny. It seems that it is shifting early, and basically not when its supposed to. I talked to a friend at work and he was telling me that it is due to the fact the the tires are bigger. Is this true? I was leaning towards it was due to the weight of the wheels, which are 50lbs with tires....
So what do you guys say?
Old Apr 24, 2008 | 04:56 PM
Fr33way™'s Avatar
Wild for Width
The only thing that would change would be your overall final ratio (revs/mile). 50lbs is not that bad, most wheel combos that arn't lightweight specific tend to be anywhere from 45-55lbs. The stress on your axles from being low is a much more tangible difference than the weight of the wheels.
Does it downshift/hunt for gears alot?
Old Apr 25, 2008 | 06:57 AM
WhiteA32's Avatar
But I have been lowered ever since Aug last year. No problems.
No it doesn't hunt for gears.
Say if I am driving down a street. Its basically would shift before it needs to. So I have no power when I am in the next gear.
If that makes any sense.
I ordered tires as of a few days ago, so we shall see if that fixes the problem.
ah2002
Mar 9, 2016 01:42 PM
maximaham
Aug 20, 2015 10:23 AM
gizzsdad
Aug 19, 2015 01:01 PM
