Wheel/Tire Sizing Experts? 245/40 on a 7.5" Wide Rim?
Old Jun 4, 2008 | 08:34 AM
Turbobink's Avatar
I just upgraded from the OEM Gen4 16" rims to 18 x 7.5s off an ’03 Infiniti M45. The original equipment Infiniti tire on this rim is a 235/45/18.
I'd like to run a wider tire but still stay reasonable as far as a change from the OEM overall diameter. The tire I’ve found to be most desirable to me is a 245/40/18.
In shopping for that size tire (245/40/18) I'm finding that the acceptable rim width is 8.0” to 9.0”.
What’s got me a little perplexed is the fact that in looking at some of the application tables for various tires, some state that the acceptable rim width for a 235/45/18 (the OEM size) is also 8.0” to 9.0”.
That being said and knowing that, in fact, the manufacturer put a 235/45/18 tire on a 7.5” wide rim, would everyone think it would be safe to install a 245/40/18 tire on a 7.5” wide rim?
Old Jun 4, 2008 | 09:24 AM
BLACKonBLACK98's Avatar
Former Vendor
i think it would be safe, but i wouldn't do it. 235 is pretty fat for a 7.5" by my standards (but i'm running 235 on a 9.5 so...).
i would just stick with 235/45.
Old Jun 4, 2008 | 09:53 AM
LeX's Avatar
LeX
Nissan by Nature
i would stick with 235s. 235 40 or 235 45
Old Jun 4, 2008 | 02:26 PM
essential1's Avatar
My axles cry for mercy...
I'm running 245/45 on an 18x7.5 wheel. I got way too much meat on the wheels. Go with 235/40.
Old Jun 4, 2008 | 03:13 PM
NmexMAX's Avatar
dot dot dot ...
It's been done before, but I wouldn't do it, so
Old Jun 4, 2008 | 07:42 PM
irish44j's Avatar
retired moderator
stick with your current size.
btw, different tires from different companies have different specs depending on sidewall construction and stiffness - hence why some will fit that size and others say they won't.
Old Jun 5, 2008 | 08:23 AM
LudaTej's Avatar
im pretty sure it would be safe but juss like everybody else has said ud be better off stickin with the 235s... it's wide enough as it is...
Old Jun 5, 2008 | 10:07 AM
nowicki13's Avatar
I would NOT put that tire on a 7.5" rim. As the ratio increase (40 to 45) you get more leeway on the width of a rim you use. So you can use a 235 on a 7.5" rim in a 45 ratio, but shouldn't with a 40 ratio. Even more so with a wider 245mm tire. If you had a 50 ratio, you might be able to stick it on a 7.5" rim, but I wouldn't put a 40 on that rim. Safety and Specs aside, it wouldn't look good at all. You can put a 235/45+ or a 225 in any ratio on that 7.5" rim. You need an 8" rim for a 245/40. Keep in mind -wider tires are better traction, but lower gas mileage.
Old Jun 5, 2008 | 10:10 AM
tibal's Avatar
I just purchased some OEM 350Z Touring V.1 18's for the max. I was planning on getting some 225/45/18's for the front, and 245/45/18's for the back because of the offsets, should i instead get 235/45/18's for the back as you told turbobink?
Old Jun 5, 2008 | 01:36 PM
nowicki13's Avatar
What is the width of those rear rims? If it's 8 or 8.5" than either the 235 or 245 will probably fit. He was trying to install a 245/40/18 tire on a 7.5” wide rim -a wider tire, and smaller rim than your combination. FYI - a 225/45/18 is 26" diameter, a 235/45/18 is 26.5" diameter, and a 245/45/18 is 26.7" diameter. Your back wheel will be slightly larger than your front regardless.
Old Jun 5, 2008 | 07:55 PM
MrDicks95SE's Avatar
Offset Is Everything.
dont do it. stick with 235/40-18.
Old Jun 13, 2008 | 06:32 AM
Digitized's Avatar
I'm running 225/40R18.. 235 would be maximum I would go..
Old Feb 5, 2011 | 08:22 PM
solo413's Avatar
good choice
i currently run 235/40/18's i think its a good size n ride on the maxima!
Solo413
07 m35x
00 maxima
Old Feb 15, 2011 | 07:03 AM
CPBOYZ's Avatar
MY FRONT WHEELS R 18X8.5 +28 I GOT A 225/40/18
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
