225/45/18in tires ON A 18x9 rim??
Old Jun 4, 2008 | 05:05 PM
nycmaximakid's Avatar
anyone has pics of this??
Old Jun 4, 2008 | 07:40 PM
irish44j's Avatar
retired moderator
go wider. That size belongs on a 7" wide rim, not a 9" wide rim.
stretching tires is lame.
Old Jun 4, 2008 | 11:46 PM
Delvin's Avatar
And so is rubbing when running wider wheels with fat rubber.
If you dont mind me asking is there a reason you are going for a mildly stretched look or are you doing it for clearance issues?
Old Jun 5, 2008 | 08:12 AM
LudaTej's Avatar
yer gonna need at least a tire width of 235mm for a 9" wide wheel...
Old Jun 15, 2008 | 11:34 AM
i have 255-30's in the rear now with a sport drop and dont have any rubbing or clearance problems.
so since i have to change my rear tires since there almost done i rather go for a stretched look like on my dub plus the tires would be way cheaper.
so im guessing 225-40's for the front 18x8
and 235-40's for the rear 18x9 ??
Old Jun 15, 2008 | 10:44 PM
MrDicks95SE's Avatar
Offset Is Everything.
225/40-18
Old Jun 15, 2008 | 11:17 PM
Snypa's Avatar
loks good.^^^
Old Jun 16, 2008 | 01:10 AM
ptviperz's Avatar
Not feeling that at all. Go wider, not stretched.
Old Jun 16, 2008 | 07:01 AM
essential1's Avatar
My axles cry for mercy...
The idea is to stretch the tire to prevent rubbing. Run a wider tire and you'll rub all day.
Old Jun 16, 2008 | 09:08 AM
ptviperz's Avatar
I guess I'm old school I'd run the right width wheel. instead of a 10" width and stretched tire.
Old Jun 16, 2008 | 09:52 AM
BLACKonBLACK98's Avatar
Former Vendor
stretching tires for the sake of stretching is lame.
fixed.
stretching tires because you are so low and running well fitting wheels means you are cool. in the op's case i would say don't do it since you are not experiencing any problems with your current setup.
Old Jun 16, 2008 | 09:53 AM
phatboislim's Avatar
to answer your question yes it will work/fit
Old Jul 19, 2008 | 10:38 AM
thanks so i guess to play it save and still have a stretch look i will go with
225-40-18 for the front 18x8
235-40-18 for the rear 18x9
Old Jul 19, 2008 | 08:12 PM
Former Vendor
just get the right size (255 or larger). 225 or 235 is good for the front. you're not low enough to necessitate stretch.
its already hard enough on us stretch guys, don't make it worse by doing it for no reason.
Old Jul 20, 2008 | 03:07 AM
word.
Old Jul 20, 2008 | 07:54 AM
my car is low and i dont like how 255-30's looks which is what i have and will need to change soon. not worth to spend more money on that size tire.
Old Jul 20, 2008 | 07:26 PM
Former Vendor
spring drop /= low. but do whatever then.
Old Jul 20, 2008 | 07:57 PM
PulsarGTS's Avatar
Stretched tires makes it look like you couldn't afford the proper sized tire... jus sayn tho
Old Jul 20, 2008 | 08:51 PM
kzoosho's Avatar
Im running 225/40/19's on a 8.5 rim. Doesnt look bad but keeps me from rubbing more.
Old Jul 21, 2008 | 11:01 PM
uh what??
having an unpainted front lip makes it look like you cant afford a simple paint job. just sayn tho.
Old Jul 22, 2008 | 01:58 AM
The Law's Avatar
I R The Law
Originally Posted by Mr****s95SE
uh what??
HAHAHAHAHAHHAH!!!!!!!!!!!
Old Jul 22, 2008 | 02:01 AM
The Law's Avatar
I R The Law
So many hates in the club
Old Jul 22, 2008 | 02:21 AM
u know it. we <3 the org.
Old Jul 26, 2008 | 07:53 PM
MIK3's Avatar
You shouldn't have rubbing issues with even a 245 tire assuming you aren't going lower than 1.5". However, if you decide to stretch, watch those lips. One curb and say goodbye to your wheel.
Old Jul 26, 2008 | 08:30 PM
SurraTT's Avatar
HR Swap Pioneer
check my sig.
245 45 18
but i guesss im 18X8 idk 4 sure
personally i dont like it, i had to roll rear fenders and they still rub, front rubs when bottom out. and when turn kinda rubs splash
im lowered on maxspeed, and stock struts
edit, jus realised the sig pic was stock rear springs. its fine on stock springs but not maxspeeds, jus havent switched back yet
Old Jul 26, 2008 | 08:51 PM
Crusher103's Avatar
actually just to correct u the idea of stretching tires is to provide better turn in response(less sidewall flex), its common, look at a 350Z OEM front tires, u will find that they are slightly stretched, the vdub people took it too the extreme with like 205s on a 10" wide wheel
Old Jul 28, 2008 | 10:58 AM
Maximum I's Avatar
just to answer it all im running 225/45/18 on a 9.5 so no problems dude it will work.
Old Oct 21, 2008 | 01:56 PM
looks good
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
