350Z 6-Spoke Alloy front offset, lowering gonna be ok??
Old Aug 1, 2008 | 03:37 PM
TunerMaxima3000's Avatar
I have the 18" 6 spoke 350Z wheels (OEM) with OE bridgestone potenza's.
The front sticks out of the fender well a little bit, what I'm wondering is whether this is going to affect lowering which I'll be doing soon hopefully. I am slightly worried about clearances and am hoping that some of you have dealt with this and can let me know. If there is going to be an issue I suppose I'll have to get them machined.
BTW I am lowering about 1.5"-2"
Thanks, hoping for some solid answers on this.
Matt
Old Aug 2, 2008 | 07:03 AM
WhiteA32's Avatar
It should be around +30 for those wheels.
Old Aug 3, 2008 | 12:41 AM
MrDicks95SE's Avatar
Offset Is Everything.
the 350z setup would be a small staggered sizing. put the wider 8.5 in the rears. what tire size are you running? If its the 350z size, the sidewalls gonna be one size too tall. get the right size tire and you will be fine. ( 45 ---> 40.)
Old Aug 3, 2008 | 11:40 AM
IHAVEA2KMAXIMA's Avatar
the 6spoke z wheels are 18x8 +30 all around. only staggering is the tire size.
nothing a little stretch & camber cant fix right?
Old Aug 3, 2008 | 12:10 PM
Sorry I forgot to post tire sizes.
They are stock tire sizes,
FRONT - 225/45/R18
REAR - 245/45/R18
So I'm confused, are you saying that the wheels themselves are the same? Same offset width just with wider tires on the rear?
The tires are new, I'm not going to be changing them. So how low can I go? There seems to be a good bit of clearance to drop 1.5"-2" but as I said, I want to be sure before I get struts/springs.
Thanks guys!
Matt
Old Aug 3, 2008 | 12:14 PM
FRONT - 225/45/R18
REAR - 245/45/R18
Thanks guys!
Matt
Yep that's exactly what I'm saying if I remember correctly. All four wheels have identical spec except different tire size from factory.
I dont know much about 4th gen, but I would guess that you will need to shave or roll your fenders.
Old Aug 3, 2008 | 04:37 PM
WhiteA32's Avatar
I was running the same size tires on my Max. I rubbed in front, but never in back. I had them setup just like they were on the Z
Old Aug 3, 2008 | 11:37 PM
Are you sure? I recall the fronts are 8 and rears are 8.5 or am I mistaken?? I know the offsets are +30 front and back.
Old Aug 3, 2008 | 11:39 PM
FRONT - 225/45/R18
REAR - 245/45/R18
Thanks guys!
Matt
the aspect ratio (sidewall size) are one size too large. your speedo and odo will be off as the diameter of the tire is larger than OE 4th gen specs. it will fill in the gap nicely but its not to spec. run these if you like, but id get the right tire size nonetheless. 235/40-18 would be most preferable.
Old Aug 4, 2008 | 07:48 PM
I am pretty sure they are 18x8 +30 all around just like the 7spoke G wheels.
The 2nd gen 5spoke touring wheels are staggered 18x8 +30 and 18x8.5 +33.
Old Aug 5, 2008 | 07:29 AM
How much were you lowered front / back?
Funny thing about that is, my speedo is dead on now, it must have been off before.
And the setup actually only raises about around .90 (almost an inch) from stock setup.
I haven't got the money to put the 'ideal' tire on so that is a no go.
Like I said, I've raised it about 1" from stock just by installing the tires, shouldn't I be able to lower it at least 1.5" ??
Old Aug 5, 2008 | 10:12 AM
Hexon's Avatar
You would have to have some stiff springs or struts. If you have any body roll you could rub the fenders. I think you need to roll your fenders
Old Aug 5, 2008 | 07:54 PM
Maybe I'll dish out the cash for adjustables, I'm in Canada too so its gonna be low on the winter tires, and then I've got some room to play so I can find the right settings.
More money than I was planning on spending though.
So far this is not the good news I was hoping for!!!!
Thanks for replies though guys.
Matt
Old Aug 5, 2008 | 07:59 PM
WhiteA32's Avatar
I am some where down 2+ inches.... umm see sig is all I can say. I don't have an exact measurement.
Old Aug 6, 2008 | 11:56 PM
^thanks man,
that helps, I think I'm gonna be safe with the 1.5-2" drop
AcuraLegend
Sep 22, 2015 04:22 PM
umnitza
Sep 1, 2015 01:03 PM
twotonezed
Aug 16, 2015 11:41 AM
soon2ownmax
Aug 13, 2015 02:19 PM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
