Valve stem recall/alert
Old Sep 3, 2008 | 10:23 PM
lightonthehill's Avatar
Dill Air Controls (the latest name for a company which has been around over half a century) has issued a recall/alert for several million bad valve stems. These were made in China (of course), and are prone to premature cracking and loss of air. Several accidents and one fatality have been traced to these stems failing.
These recalled stems have been used by many tire sales outlets/stores during the last few years. I bought a set of tires at Discount Tires 17 months ago, and recently received a letter warning that these stems should be replaced immediately. I took my car to their store, and Discount Tires replaced these stems and rotated and balanced my tires free of charge.
As Dill is the leading supplier of valve stems, anyone who has bought tires in the past two years might want to check with the place you bought the tires and find out if your stems are part of the recall. If unsure, check your stems very carefully every month or two for any crack, however small.
Old Dec 23, 2008 | 07:44 PM
9378max's Avatar
wow, bumping this up. my driver's side tire went flat to a degree of about 15psi when I got home. lifted the car up and didn't find any punctures. then realized that it was the cheap valve stem i got from discount tire (they sent out a recall, but i was lazy and ignored it !!! So go check your valve stem now!!!!!
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
tardrex
Sep 11, 2015 07:35 PM
03VQMAX
Sep 5, 2015 03:47 PM
