offset advice
Old Nov 18, 2008 | 08:14 PM
airMaxSL's Avatar
offset advice
does anyone know if these rims would go flush or stick out? im not good with the whole offset thing and im def. getting these rims. any advice?
Stern Wheels
Style: ST-1
Bolt Pattern: 5x114.3
Offset: +38mm
Finish: Hyper Silver
Condition: Brand New
Old Nov 18, 2008 | 10:46 PM
choiiiiiiiiiii's Avatar
roll your fenders
Old Nov 18, 2008 | 10:57 PM
MrDicks95SE's Avatar
Offset Is Everything.
the front will sit okay-flush but the rears, id run a 20mm spacer to push that sucker out. as far as fender rolling is concerned, it all depends on tire size and how low of a drop you are on. just run it and then roll if needed.
Old Nov 19, 2008 | 05:43 AM
BLACKonBLACK98's Avatar
Former Vendor
what ^ said except for 15mm spacers for flush, no poke.
if you're buying new wheels might want to just go staggered and get it right off the jump.
Old Nov 19, 2008 | 07:40 AM
airMaxSL's Avatar
i know, but im dead set on these wheels thanks for the input though. so where do you get these spacers from and is there a certain kind that's better than the other?
Old Nov 19, 2008 | 07:42 AM
airMaxSL's Avatar
what tire size you guys recommend, i don't want anything too lowpro
Old Nov 19, 2008 | 08:54 AM
Former Vendor
for spacers i would stick to the major brands: ichiba, eibach, or h&r.
tire size is going to be dependent on how much clearance you need. actually going by you sn you are probably in a 6g and i have no idea on tire or spacer size.
Old Nov 19, 2008 | 01:23 PM
what ^ said.
whats your stock tire size? use the miata tire calculator to figure it out.
http://www.miata.net/garage/tirecalc.html
Old Dec 2, 2008 | 07:34 PM
24K on da way's Avatar
its going to sit flush..just make sure ur not slammed on coilovers..it will be a perfect fit
Old Dec 3, 2008 | 12:24 AM
MIK3's Avatar
My A34 Rays are 19x85 ET35 and they are perfectly flush up front. Rears could use about 15mm. As far as tires, assuming you don't go lower than like a 1.5" drop, you will be fine with 245/35/19s, they are perfect profile and a good width.
I'm just hoping weight is not a factor for you, Stern is known to be on the heavier side. I'm not too sure on their build quality however.
Old Dec 3, 2008 | 06:30 AM
Deckdout2's Avatar
Play with my balls
Don't get Ichiba. Their studs suck like a ****. I'm on my 7th try and they are giving me the hardest time out of anything i've installed before. They just don't grab on to the hub well at all, and had a few round out on me. Just get the H&R with the correct knurl size for your car. 14.xx I believe.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
