Wheel Spacers questions
Old Nov 24, 2008 | 02:22 PM
supermanrox305's Avatar
What are the pro's and con's about wheel spacers or wheel adapters.
Like those one's here.
Old Nov 24, 2008 | 03:32 PM
rxm6's Avatar
the little that i know...
if wheel adapters are not hubcentric there will be vibration
also....
if your wheels do not have space in between where the bolts slide through, then the bolts attached to the original lugs will hit the wheel and you will not be able to attach your wheel
Old Nov 24, 2008 | 06:02 PM
also....
The rims have 5 lug universal bolt up pattern.
Old Nov 24, 2008 | 07:20 PM
RA030726's Avatar
I'm nutty for Nissans
Chances are they wont fit if they are universal. Usually the mounting flange is flat on wheels like that.
I have bolt on spacers on the rear, 20mm IIRC. They are Egay specials with hubcentric rings. No problems so far.
Pros:
Stance, supposedly wider is better
You can even the front and rear offset
More tire clearance on the inside
Changes scrub radius and roll center
Cons:
Possibly more wear on the wheel bearings and/or ball joints
Less tire clearance on the outside, can lead to fender rolling
Possible damage to car if installed improperly or not checked regularly
Wheels need to have room on flange to fit lugs
Old Nov 24, 2008 | 09:07 PM
Pros:
Cons:
Ok thanks for info.
Old Nov 25, 2008 | 05:56 AM
Deckdout2's Avatar
Play with my balls
I recommend the H&R spacers, there's a new 15mm DRM version with the studs already mounted to the spacer that will just bolt up to your existing lugs. You just have to make sure there is enough clearance between the OEM studs and your wheels. If not then you will have to shave your OEM studs. This set should be out by mid Dec, but is on H&R's website already. Anything below that you will need to use the DRS version with the new extended studs. Anything above 15mm I would go with the DRM for a simpler install. The knurl you will need is 14.25mm, make sure you get that one. Mine mistakenly came with the 12.85mm knurl, but it's getting replaced soon.
Old Nov 25, 2008 | 09:19 AM
My wheels are 18x7.5. If i go if 15mm spacers would that give me the 18x8 look or would i need a more mm spacer?
Old Nov 25, 2008 | 10:09 AM
Also does anyone know the center bore for the 4th gen maxima?
Old Nov 25, 2008 | 12:55 PM
Deckdout2's Avatar
Play with my balls
It depends on the offset of your wheels for them to look wider with which "mm" spacer, but 7.5 will never look like 8 unfortunately. You wheels will just be pushed out more for the "perception".
Old Nov 25, 2008 | 12:56 PM
Deckdout2's Avatar
Play with my balls
Center bore would be 66.2 for 4th, 5th, and 6th gens.
Old Nov 26, 2008 | 04:15 AM
yea thats what i want for it just to look like if its wider
Old Nov 26, 2008 | 06:07 AM
Deckdout2's Avatar
Play with my balls
Just measure from the face of the wheel to how far out you want it to sit up to or beyond the fender, that's the spacer size you will need.
Old Nov 26, 2008 | 07:56 AM
aight cool thanks alot man. I have asked questions before on the org and no one helps me out thanks alot man.
incubusjohnny
Nov 3, 2015 05:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
umnitza
Sep 1, 2015 01:03 PM
Maxboy23
Aug 11, 2015 11:59 AM
