Hub Centric Rings
Old Feb 26, 2009 | 08:50 AM
JayMAX22's Avatar
Hub Centric Rings
What up guys. I need to get some hub centric rings but I'm not sure what size I need. How can I figure that out? I have an 04 with Foose Spank 5 rims 20 x 8.5. Any help would be greatly appreciated.
Old Feb 26, 2009 | 09:12 AM
n3985's Avatar
大陆弟弟
I have a set of brand new hub rings for our cars which I didn't need, $10 shipped if you are interested.
Old Feb 27, 2009 | 09:08 PM
z32drifter's Avatar
Measure the diameter of the center of the wheel, most aftermarket wheels have a 73mm center bore. you could also contact Foose, I'm sure they can tell you the center bore or sell you hub rings.
Old Mar 3, 2009 | 11:56 AM
lawheels's Avatar
Why do you need them. We have proven time and time again that they usually cause more problems then good. Wheels are drilled lug centric. if you have a shake then it is a balancing issue.
Old Mar 3, 2009 | 03:18 PM
PulsarGTS's Avatar
I ran brand new balanced wheels with no hubcentric rings and had a shake at 40mph or above, installed the rings and no shakes at any speed. Ive ran them on all of my aftermarket wheels without a problem.
Old Mar 3, 2009 | 03:20 PM
Old Mar 3, 2009 | 05:19 PM
z32drifter's Avatar
I fail to see how a hub-centric ring will cause an issue. There are a few good reasons to use hub rings. One, on a hub-centric car the hub is an intregated part in the wheel support system..ie the hub supports the weight and the lugs/bolts clamp the wheel to the hub. Two, 99% of shops use a hub-centric balancer.
So if the aftermarket wheels are drilled lug-centric, and the shop balances them hub-centric you can see how not using hub rings could cause an vibration.
Can anyone think of a modern lug-centric car??? I can't.
Old Mar 4, 2009 | 10:10 AM
IHAVEA2KMAXIMA's Avatar
I'm taking my hubrings off asap cuz it's proven time after time to be bad.
Old Mar 4, 2009 | 01:29 PM
Dibs on those just to let everyone know.
Old Mar 4, 2009 | 01:35 PM
Matt93SE's Avatar
STFU n00b!
Proven time after time?
Umm no. our cars were designed around hub centric wheels. removing the rings only causes problems.
That assumes you have quality rings though. don't mess with those cheap plastic ones. spend a few extra bucks and pick up some aluminum or steel ones at a good wheel shop. I've had the set on my Maxima for 8-9 years now and never had a problem with them. Every now and then I'd take them off to clean the wheels or whatever and I'd wind up with a vibration. Put the ring back in and smooth sailing.
Try listening to people that make sense every now and then, not noobs that come on here and start talking out their ****.
Old Mar 4, 2009 | 01:44 PM
Old Mar 4, 2009 | 03:10 PM
lol my little internet sarcasm just failed catastrophically
Old Mar 4, 2009 | 09:04 PM
BLACKonBLACK98's Avatar
Former Vendor
ha ha... sarcasm > joo
Old Mar 4, 2009 | 09:20 PM
ZaxWhite97Max's Avatar
lol! I was just looking at this and then at the bottom the google add was
"DO YOU HAVE VIBRATION IN YOUR NEW WHEELS?"
Use hubcentric Rings to install your aftermarket wheels
on your car, hubcentricly helping to fix your vibrations.
Justforwheels.com "we also have tuner wheel locks"
noice.
owned by google ads
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
londonflu
40
Sep 25, 2015 09:11 AM
DBear
Sep 14, 2015 08:33 PM
