Light Weight Wheel Recommendations
Old Aug 22, 2009 | 09:23 AM
  #41
bryan163's Avatar
Originally Posted by MIK3
If you ever end up winning the lottery...
Wedssport All-CF wheel ~ 6.5lbs ($10k/set )
Sorry for mentioning the CF's again, but who could you even trust to mount the tires on these things?
Old Aug 22, 2009 | 09:41 AM
  #42
bryan163's Avatar
Originally Posted by Apollos2
Okay what are your opinions and recommendations on these 350z 17in wheels.
The fronts are 225/50, 8.5", weigh 42 pounds
The rears are 235/50, 9", weigh 48 pounds
Is that considered light weight?
Are those a forged wheel? The 6th gen Altima SE-R wheels say "FORGED" right on the rim. idk about using a staggered set on a fwd car. Would you run the 9s on the front?
Old Aug 29, 2009 | 11:14 AM
  #43
Apollos2's Avatar
Will these fit? Gram Lights
http://denver.craigslist.org/pts/1336683967.html
Old Aug 29, 2009 | 01:30 PM
  #44
MrDicks95SE's Avatar
Offset Is Everything.
really? realllly?????
to answer your "question," yes. sunken battleships.
Old Aug 29, 2009 | 01:38 PM
  #45
Apollos2's Avatar
Originally Posted by Mr****s95SE
really? realllly????? .........to answer your "question," yes. sunken battleships.
You lost me sunken battleships?
Seems to me like they would fit 17.5 5x144.3 but I'm not 100% sure about the offset or the center bore.
(17x7.5JJ, 5x114.3, +40mm offset, 67.1mm center bore, 17.5lbs each) with Toyo Proxes T1-R (T1-R 235/45ZR17 97Y) tires
Old Aug 31, 2009 | 10:27 PM
  #46
Fast1one's Avatar
Sunken battleships is a term referencing a lack of width and desirable offset. In other words, they won't be flush with the fender, at all. Sunk in the fender, get it?
Old Sep 1, 2009 | 06:21 AM
  #47
Apollos2's Avatar
Got it, thanks for the help.
Too bad, would have been a good price. Oh well back to the drawing board.
Old Sep 1, 2009 | 09:27 AM
  #48
Fast1one's Avatar
Look for around 8.5 +30-35 all around to be flush. With simple math you can account for different widths. Your car will look more aggressive than the above sizes, and you will thank us
Old Sep 2, 2009 | 12:23 PM
  #49
u can fit more wheel and rubber in our wheel wells. just gotta be man enough to do it.
Old Sep 2, 2009 | 12:29 PM
  #50
Apollos2's Avatar
LOL it doesn't have anything to do with man enough to do it, has to do with know what size/offset I need. Once I find them if I have the $$, I'm in.
http://denver.craigslist.org/pts/1354291288.html
Four (4) Kazera Rims mounted with Hoosier A3S05 race tires
18"x7" Rims
Bolt Paterns: 5x100 and 5x114.3
Lightweight Rims: 18lbs
Hoosier Tires: 225/40/18
Offset not given but again, only 7in wide I have 8in width on there now.
Old Sep 2, 2009 | 10:16 PM
  #51
Fast1one's Avatar
Well duh, my suggestion was a conservative one
Old Sep 4, 2009 | 07:58 AM
  #52
Nealoc187's Avatar
SLOW
Yes those gram lights would have fit just fine. They'd be inside the fenders just a little bit.
Old Oct 1, 2009 | 01:48 PM
  #53
Apollos2's Avatar
I ended up moving to my winter setup. Big O EuroTour tires and my MSR 17in wheels
I weighed everything.
18"Boss 304s with rubber 51lbs
17" MSR wheels with rubber 40-41lbs.
I weighed them several times and that's what I kept coming up with. My winter set up seems a little light?
I tried to get to the track last night but it didn't happen.
vingodine
45
May 21, 2016 12:46 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
