Another "ZOMG WILL IT FIT?!" thread...
Old May 23, 2009 | 05:46 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Ok, so one potential candidate for teh new shooz have the following specs:
18x8.5 w/ 45mm offset, which, to the best of my abilities, has been shown to provide no clearance issues. I might be wrong.
Now, I am looking to pair these with a set of tires at 225/60 R18.
So my questions are: will the wheel fit? and will these tires fit?
Old May 23, 2009 | 07:12 PM
Tatanko's Avatar
Bacon Lover
225 seems REALLY skinny for an 8.5" wide wheel.
Old May 23, 2009 | 08:59 PM
NOTE: I'm not looking to have a ghetto fab stretch/low profile look. I drive A LOT and need the tires to perform more than anything else.
Good call on the tire, thanks for the heads up.
Old May 23, 2009 | 09:03 PM
Puppetmaster's Avatar
235/40/18 or 245/40/18.
With that weak of an offset, you will need to consider your brakes too, if you have an aftermarket brake kit. The spoke pattern will also affect how much clearance you have.
Old May 23, 2009 | 10:06 PM
Goddamit, shopping was supposed to be fun.
I was sold on the Enkei's until I can across the Stern ST-1s...they look agressive as hell and are the first set of wheels that have really caught my interest.
Stock brakes, you still think there would be clearance issues?
Old May 23, 2009 | 10:10 PM
Judging by the spoke pattern, they look like they'll clear even the 6th Gen brakes. Is there no better offset option? Well, if necessary, it isn't anything that some spacers can't fit.
They look kinda heavy though... a bit different from your previous thread on light 17s.
Old May 23, 2009 | 10:19 PM
They are about 26lbs, IIRC. I like the Enkei's, but they are bit "vanilla" compared to these. For the sake of my wallet, though, I'm likley to just go with the RPF1s.
Old May 23, 2009 | 10:24 PM
Ok, nm, going with RPF1s
Old May 23, 2009 | 10:46 PM
Fast1one's Avatar
Why the weak sauce fitment though?
Old May 24, 2009 | 02:06 AM
MrDicks95SE's Avatar
Offset Is Everything.
total weaksauce fitment but whatever you want.
stock brakes, no clearance issues. youll be fine across the board.
tire size on 8.5, 245/40
Old May 25, 2009 | 10:01 PM
MIK3's Avatar
Metal, I wouldn't rush with your wheel selection. I think I said "these are my next wheels" half a dozen times within 8 months before I chose the Rays. I was actually considering the exact Sterns you mentioned until I realized how damn heavy they were for 18". I think we could better help you with your wheel choice if you state what you're looking for in a wheel(i.e. aesthetics, weight, strength). For an 8.5" tire, I'd go 245/40/18. Also, are you dropped? The sidewall on my Rays are pretty much flush and their 8.5" on a 245 series tire.
I believe an optimal set up would be an 18x8.5" ET38 or 35 w/ a 245/40/18 all-season.
Old May 26, 2009 | 08:49 AM
BLACKonBLACK98's Avatar
Former Vendor
cause good fitment is "ghetto fab".
might as well ride stock on those sizes.
Old May 28, 2009 | 09:27 PM
Yeah, MIK3, I'm in mode trying to figure out what I want. I am relativley certain on the RPF1s, step in here and add your $0.02
Old May 29, 2009 | 11:22 PM
steven88's Avatar
Need A Light?
how about 17x8 ET37 with 235/45/17?
do they sit a little tucked in, yet wide enough to make a difference? 4th gen and 5th gen?
Old Jun 2, 2009 | 08:08 PM
z32drifter's Avatar
Here's the RPF1s on my 4th gen 17x8.5 +40 255/40 front 17x9.5 +38 275/40 rear.
IIRC the 5th gen car has even more room
Old Jun 3, 2009 | 12:50 AM
dude you should just make that pic your sig with specs.
Old Nov 6, 2009 | 10:11 AM
DonSalchichon's Avatar
That pic really makes me want my 96 max back. Good looking car man!
Last edited by DonSalchichon; Nov 6, 2009 at 10:24 AM. Reason: for got to add the "me" to my sentence
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
