Offset/size calculator question
Old Nov 1, 2009 | 07:20 AM
chrisexv6's Avatar
Running through different scenarios on the Rims-N-Tires calculator, I notice for wheel wells it says "will fill out wheel well extra ...."
What do they mean by "fill out" ? Does that have anything to do with how far the wheel comes out towards the fender? (i.e. more flush with the body)....or is more of a distance between the outer diameter of the tire vs the wheel well lip?
Just trying to determine what wheel/tire combos wont rub on my car......should I be looking at the "fender" section of the calculator? Ive always called up front fenders, but in the back "wheelwells" so I might be a little confused.
Thanks in advance.
-Chris
Old Nov 4, 2009 | 08:12 PM
MrDicks95SE's Avatar
Offset Is Everything.
the wheel well is the entire "tub" or "well" the wheel sits in whether it be front or back. do the calculations using the wheel/tire calculator from the miata site in the stickied links. measure and figure it out. this has been discussed NUMEROUS times over and over again. tire sizes are also discussed as well.
other questions you need answered are:
are you lowered? how low? tire size? wheel size? wheel specs (ie offset and width)? cambering? etc. please use the SEARCH functions as it is readily available. dont be lazy.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
