drag radials
Old Feb 8, 2010 | 01:33 PM
timwdv's Avatar
drag radials
any of you run these nitto nt555r drag radials? or use anything wider than a 255 on your stock rims, i thinkin of runnin these 285/35 18 nittos on my 6th gen stock wheels
Old Feb 12, 2010 | 05:03 PM
timwdv's Avatar
any of you guys have ran anything wider than a 255/ tire on your maxima's?
Old Feb 17, 2010 | 08:20 AM
Nealoc187's Avatar
SLOW
I have run Nitto DRs, though not in that size (I had 245-45-17s).
There is no way in hell you're fitting a 285-35-18 on a stock 6th gen rim. None. I doubt they would ever get the bead to seal, and if they did you'd be driving on a time bomb - in danger of the bead unsealing and the tire coming off the tire on every turn. Forget that idea, if you want to run that tire you need a much much wider wheel.
Maxima_Joe
Nov 25, 2015 08:19 AM
VQ'ed
1/4 and 1/8 Mile Racing
Aug 30, 2015 05:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
Xi MaX SC
Aug 7, 2015 08:47 AM
