Looking to run 20's "HELP"
Old Mar 10, 2010 | 03:30 PM
dwade27's Avatar
Im looking to run so 20's (yes i said it) and staggered. its a 01 maxima no drop yet but looking into that as well (coilovers).
the setup im looking into using is
20x8.5 F +35mm
20x9.5 R +40mm
not sure what tires i want to use just yet but probably 245-35-20
jus looking for help from the guys that seem to know.
oh and heres the link with the info on the rims
http://www.1010tires.com/wheel.asp?w...eelmodel=Image
Old Mar 10, 2010 | 06:29 PM
mrfliboi's Avatar
the lower the offset number the farther they stick out so jus make sure the back has a lower number then da front.. cause the front stick out more already..
Old Mar 10, 2010 | 06:50 PM
Fast1one's Avatar
WRONG. It is the combination of width AND offset which dictate the amount of protrusion. In this case, you want a LOWER offset in the front than the rear because of the difference in width. One inch equates to 25.4mm or about 12-13mm added to each side of the centerline. In order to match the front of 8.5 +35 with a 9.5 rear, you would need a +47 offset in the rear to match the front.
However, the maxima (with no camber) is about 10-15mm more sunk in the rear. It is usually desirable to run at least -1-1.5 degrees of camber in the front. Those sizes are fine.
Run 225 in the front and 245 rear. Roll your rear fenders for clearance.
Old Mar 10, 2010 | 11:12 PM
perkman87's Avatar
Thats The same offsets I was running btw so you should be good.
Those wheels are sick btw!!!!
Old Mar 11, 2010 | 12:54 AM
dwade27's Avatar
thanks for the input guys.
perk your max was sex on wheels when you were on dubs, to bad you couldn't run the z32 calipers with them.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
