Wheels for 2k2 Max
Old Aug 23, 2010 | 12:21 PM
dtp308's Avatar
Wheels for 2k2 Max
Hey general question will a 18x8 with a 50 offset work on a 2k2 Max. Planning on wrapping them in 245 45 18
Old Aug 23, 2010 | 12:28 PM
NmexMAX's Avatar
dot dot dot ...
I would go with a lower offset. To be certain that they will fit, use this calculator to see what the dimensions are with respect to the OE Se's.
Stock SE's are +45 17x7.
Results:
Your new wheel will have the following chracteristics:
The clearance from stut housing to the inside of the wheel will be 18mm LESS
The outside edge of the wheel will EXTEND an extra 8mm
Old Aug 24, 2010 | 12:10 PM
dtp308's Avatar
Thanks for the info definetly not trying to get the frog look (sticking out from fenders)
Old Aug 24, 2010 | 12:16 PM
phatboislim's Avatar
yes it will.
matts95max
Apr 23, 2025 10:44 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
BkGreen97
Apr 2, 2016 05:47 AM
MaxLife17
Sep 8, 2015 02:36 PM
boomerbrian
Sep 4, 2015 08:25 AM
