Best wheel/tire size for softest ride on 6th gen. ?
Old Sep 5, 2010 | 11:47 PM
04SL's Avatar
I currently have 18x8 wheels (30mm offset) with 245-45-18 tires on a 2004 Maxima and the ride is too rough (of course the Chicago streets dont help). By they way, they fill the wheel wells perfectly.
Im looking to get a smaller wheel with bigger sidewall and was considering late model g37 17x7.5 wheels (45mm offset) with 225-55-17 tires.
Is this too big of an offset ? Will I need spacers ?
Or can anyone recommend an ideal size for a soft ride while still somewhat filling the wheel well and not looking too "tucked into" the car.
Thank you
Old Sep 6, 2010 | 07:47 AM
jlguru's Avatar
I can't comment on your proposed alternatives.
But - IMHO - there's nothing wrong with wheels or tire size you have now. Ride quality is more a function of tire construction and suspension design than wheel size.
If your only goal is to get a softer/smoother ride you only need tires designed to perform in that manner. Forget the "Ultra-High" performance selections and look for "Touring" or "Grand Touring" tires. Check out TireRack.com for a selection of these types of tires.
If your goal is to get a higher aspect ratio (55 vs 45) to lessen damage caused by potholes, then that's another issue that I'm not qualified to comment on.
A telephone call to Tirerack.com might be a good thing. They appear to have qualified staff that can consult with you on these issues.
Live long, and prosper
Jerry L. Gubka
Old Sep 6, 2010 | 09:29 AM
04SL's Avatar
Thanks for the input. Part of the reason Id also like to get a smaller wheel is because of these horrible Chicago roads/potholes. A good set of new 18" tires runs about $600, while a set of 17" take-offs goes for about $900 (rims and tires).
Going forward, I also figured Id keep the cost of tires down with a 17".
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
