G35 19inch Rays on a 4gen
Old Dec 19, 2010 | 03:45 PM
t6378tp's Avatar
Turbo 3.5
Question would not need spacers with this setup, I already have some 15 and 25mm spacers and want to know before I sell them
Old Dec 19, 2010 | 06:10 PM
max_dreamer's Avatar
well ive got the 8.5's front and rear. fronts sit almost flush. with the 8's they may be a little inside but definitely not enough for a 15mm... rears are inset just a little. if your dropped like i am, youll rub on the left side because of the rear beam. and if its an extreme drop youll rub both sides. fenders pulled now, i might do a 5mm on the rears...
need more info?
Old Dec 19, 2010 | 06:45 PM
t6378tp's Avatar
Turbo 3.5
need more info?
I have the staggered rays that came on a G35c with 225/40/19 front and 245/40/19 rear and plan to reuse my tein s-techs 2.2inch front and 1.8inch rear drop.
So from the sounds of it no spacers will be needed
Old Dec 20, 2010 | 08:03 AM
hectorc's Avatar
Upper Midwest Wheel Whore
Spacers will not be needed with a S Tech drop.
Old Dec 20, 2010 | 08:07 AM
phatboislim's Avatar
id say no as well. from that pic, 15 and 25 mm would bee too much
Old Dec 20, 2010 | 01:23 PM
t6378tp's Avatar
Turbo 3.5
Thanks guys, look out for a icba v2 wheel spacer with built in studs thread
Old Dec 20, 2010 | 01:44 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
NewMax03
Oct 7, 2015 08:27 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
03VQMAX
Sep 5, 2015 03:47 PM
