ASA AR1's have some questions
Old Apr 16, 2011 | 12:18 PM
jeff5347's Avatar
Ok so i am looking at a set of ASA AR1s with tires. They are 17x8 with a stated 45mm offset.
I really like the look and think they will go well with my silver max
Question(s) is this
1: With a 45mm offset at 17x8 forthe AR1 and the GLE rim being a 40 or 42 offset (not sure of and 03GLE rim offset) at 17x7, will there be enough clearance to not rub. Tire size will stay the same as i have at 225 50 17
2. The GLE rims weigh in at 23.8 and the ASA AR1 is 21.2. So there is a 2.6 lb difference. With that weight saving with there be any noticeable difference or is it so little i wont feel anything?
Old Apr 16, 2011 | 12:36 PM
They won't rub since that offset is pretty conservative and high. You might notice the weight saving since its a little over 10lbs.
Old Apr 16, 2011 | 12:49 PM
VQ'rInWLA's Avatar
I remember seeing a thread with someone putting these on pretty recently (within the month). Was on a 6th gen though. He put up pics. Ill see if I can find it.
Old May 30, 2011 | 08:18 AM
GETukrainian's Avatar
I have a used set up for sale if you are interested. They are 18x8 and I was running a S-Tech drop with no rubbing. Here are some pics:
the only pic with a drop:
before drop:
I'm also located in CT so fairly local.
/shameless plug
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
