Rota slipstream wheels
Old Jan 16, 2012 | 08:02 AM
JClaw's Avatar
http://www.racinglab.com/rota-slipstream-0005.html
Do those wheels fit our cars? With +40mm backspacing? I have a 97 SE 5-speed.
Pattern: 5x114.3
Offset: +40mm
Hub Bore: 73mm
Weight: 15 lbs
Old Jan 16, 2012 | 08:10 AM
They'll sit sunk like a mother****er but they'll fit.
Get some hub rings with them as well.
Old Jan 16, 2012 | 08:28 AM
phatboislim's Avatar
15x7 though?!? are you just using these for the track?
Old Jan 16, 2012 | 09:56 AM
JClaw's Avatar
Yes for the track, 205 50 15 Mickey thompson drag radials.
Do you mean spacers?
Has anyone actually tried them?
Old Jan 16, 2012 | 11:25 AM
No. You need hub rings because the center bore on the wheel is bigger than 66.2mm. You can get them on eBay for extremely cheap.
Old Jan 16, 2012 | 01:10 PM
JClaw's Avatar
What size hub rings do I need?
Surely I can get them locally...? I don't like dealing with ebay.
Are those good?
http://www.ebay.com/itm/Milled-Audi-...item2ebaa457d1
It says 66.56 to 57.1 mm.
Old Jan 16, 2012 | 03:24 PM
What size hub rings do I need? Surely I can get them locally...? I don't like dealing with ebay. It says 66.56 to 57.1 mm.
You need 66.1mm to 73mm rings. Just look up Maxima hub rings on eBay.
Old Jan 17, 2012 | 11:16 AM
JClaw's Avatar
Found some:
http://www.ebay.com/itm/73-1mm-66-1m...item3f128337a8
Old Jan 17, 2012 | 12:10 PM
Nice and they're metal FTW. Plastic ones suck.
Old Jan 17, 2012 | 07:06 PM
BEJAY1's Avatar
Conecarver
Curious why you say that bout the plastic ones?
Old Jan 17, 2012 | 08:54 PM
I've had a few that have broken in the past. I doubt that would've happened if they were metal.
Old Jan 17, 2012 | 11:51 PM
Nealoc187's Avatar
SLOW
I've melted plastic hubcentric rings on the road course. very doubtful that would be an issue on the street or at the drag strip though.
anyways, yes those will work. they also make them in 15x7.5 and 15x8. the 15x8s are really rare though. i bought one of the only sets i could find probably 3-4 years ago, and sold 2 of them to aaron.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
