will 18x8 20mm offset fit my 5.5 se
Old 07-19-2012, 08:52 PM
bryanakaslim's Avatar
im looking a 18x8 20mm offset f
18x9.5 20mm offset r
bryanakaslim is offline
Old 07-20-2012, 01:14 PM
so no one knows if that will fit
Old 07-20-2012, 01:20 PM
Amerikaner83's Avatar
Look in the stickies and waht-not, other threads too...you ain't gonna get spoonfed...
but yes it will fit. Whether or not it will poke...that's up to you to find out.
Amerikaner83 is offline
Old 07-20-2012, 02:19 PM
I'm nutty for Nissans
JSutter's Avatar
I had a set of 18x8 42mm offset with a 20mm spacer for the rear wheels. Rear should fit good. Front would poke out.
JSutter is offline
Old 07-24-2012, 10:09 AM
cjones450's Avatar
im running a 18x9.5 +20 all around with no issues im running 215/40/18 tire
cjones450 is offline
Old 08-02-2012, 01:43 PM
machete's Avatar
Rear will be fine,u will need spacers for the front
machete is offline
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
BLACKKILA.GTR
09-29-2015 11:23 AM
Pied
09-26-2015 03:29 PM
Quick Reply: will 18x8 20mm offset fit my 5.5 se
