Center cap fitment issues
Old 08-06-2012, 02:57 PM
pdpaiste's Avatar
Hey guys I've got a slight problem. I recently installed some wheels on my '95 se from an Altima coupe. I can't get my center caps to fit because the center bolt on all four wheels sticks out too far. Would you recommend some spacers or is there another solution? The first photo is one of the front wheel and the second is the rear. Thanks in advance!
pdpaiste is offline
Old 08-06-2012, 05:03 PM
Fstrsn's Avatar
If you have the clearance a 5mm spacer should fix that issue.
Fstrsn is offline
Old 08-07-2012, 12:34 PM
pdpaiste's Avatar
Thanks man. I'll give that a shot.
pdpaiste is offline
03-12-2020 12:06 AM
captchaos
03-15-2016 12:18 PM
conansriver
11-18-2015 02:46 PM
dcam0326
09-07-2015 07:26 AM
Quick Reply: Center cap fitment issues
