16x8 nissan oem rims on a 4th gen?
Old Sep 26, 2012 | 10:39 AM
Rob_0126's Avatar
Hey folks. I need a quick answer if possible.
Would stock 16x8 oem nissan rims fit my 95 maxima?
Would it be same offset and if not how much difference?(bearing failure issue)
I have the stock 15x6 steel rims on now.
Also, would 205/60r16 tires fit a 16x8 rim correctly?(closest diameter to stock)
Any scrubbing of suspension/fender wells or bottoming out possible with that tire setup?
Here are the rims:
http://greenville.craigslist.org/pts/3164424200.html
Old Sep 26, 2012 | 10:44 AM
Amerikaner83's Avatar
I have 215-55-16 on my stock 16x6.5 SE wheels...I would not go 205 on those, they will not fit. 235 maybe. Something like 235-50-16 or something...
The pic shows a 0 offset? That ain't right.
Old Sep 26, 2012 | 10:54 AM
0 offset? IIRC, those are 240SX wheels and I don't recall them being that aggressive.
205s would be a stretch on 8s. I wouldn't recommend it unless necessary.
Old Sep 26, 2012 | 11:50 AM
Rob_0126's Avatar
To run 205/60r16s do i need to go oem max 16's then?
this particular size, the tires are about the same price as 205/65r15s.
looks like id have to run 225/55r16s with those rims and they are significantly higher.
looks like they would stick out quite a bit too.
Hate to pass up this deal but it just wont work with my budget.
EDIT: are kumho tires a good brand?
http://www.discounttire.com/dtcs/fin...&fcb=&sw=false
Old Oct 2, 2012 | 09:57 AM
Dave H.'s Avatar
To me that ad looks like only one wheel. A s14 wheel size 16x6.5 with 40 offset. I have the same ones and can check size when i get home.
Old Oct 3, 2012 | 06:53 AM
Dave H.'s Avatar
Confirmed...16x6.5 40 offset
halfpol
Oct 17, 2022 12:16 PM
Finkle
Sep 27, 2015 09:53 PM
03VQMAX
Sep 25, 2015 04:19 PM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
