2003 SE Tire Size Question 19"
Old Dec 29, 2012 | 03:20 PM
The Duke of NY's Avatar
I have a set of 2006 G35 Rims the size are:
Front: 19x8
Rear: 19x8.5
What tire sizes are correct for my 5th gen 2003 Maxima? I bought 245x35 19 but they are rubbing. I have been getting different tire sizes from everyone i ask. TireRack.com was no help! I have had the rims for 8 months & never installed due to not getting matching answers from the people i ask. Any info is much appreciated!
I found this on a thread: "The G35 Coupe 19" Rays wheel is 19x8 with a 30mm offest (front) and 19x8.5 with 33mm offset (rear)"
Also found this: "The 19's come with 225/40/19 tires (front) and 245/40/19 tires (rear)....if you use the stock tires, there is a good chance the rears will rub because of the relative high aspect ratio"
Do i need to get spacers for them to fit correctly?
Old Dec 31, 2012 | 02:56 PM
03VQMAX's Avatar
225/40-19 all around should be fine, 10mm spacer up front with a 15mm in the rear should be flush.
ah2002
Mar 9, 2016 01:42 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maximaham
Aug 20, 2015 10:23 AM
