18" 350z on 4th gen what tires to use
Old May 14, 2013 | 06:32 PM
aleksey17's Avatar
I just picked up a set of 350z 18 inch 6 spoke wheels they are all 18x8. My question is should I run staggered tires to make the rear be more flush with the fender? I am thinking to use 225/40/18 up front and 245/40/18 in the back, or should I just get all four in 225/40?? Does anyone have pictures with the wheels on a 4th gen? I am lowered on H&R's and Sensen shocks.
Old May 15, 2013 | 01:29 PM
theblackone3.5's Avatar
yes run the staggered tires
Old May 15, 2013 | 01:32 PM
Amerikaner83's Avatar
You've already got the staggered wheels, if you run the same size tires you'll have mild stretch...but regardless, you won't want to run the wider wheels in front, so you might as well run two different tire sizes and prepare your anus for when tire rotation time comes... 225/40 and 245/40 should be fine on H&Rs.
Old May 15, 2013 | 01:46 PM
carsnwomen91's Avatar
lmao prepare anus
Old May 15, 2013 | 01:48 PM
It's true...dude on my fb group has the g35C 19 inchers and they want 200 bucks to rotate the tires, staggered and directional prepare your anus indeed
Old May 15, 2013 | 03:27 PM
aleksey17's Avatar
The wheels are not staggered they are all 18x8 from the factory but they are stamped front and rear and they run staggered tires from the factory. But that's good to know, I will get the staggered tires installed this Saturday hopefully
Old May 15, 2013 | 03:29 PM
whoa.
Well if they're all the same size you have no need for staggered tires in a Maxima.
Old May 15, 2013 | 05:04 PM
225/40 all around.
Old May 15, 2013 | 07:19 PM
aleksey17's Avatar
why did they use staggered tires on non staggered wheels on the 350z then? I want my back wheels to sit as flush as the front ones otherwise I will need spacers, so I am thinking with 225 front and 245 rear it should be pretty close
Old May 15, 2013 | 09:23 PM
Because Zs are RWD and can use a little extra grip back there.
A wider tire isn't going to make the fitment more flush. You're going to need spacers (probably 15mm to match the fronts).
Again, run 225/40s all around.
Old May 22, 2013 | 05:46 PM
aleksey17's Avatar
Thanks all, I ended up going 245/40 all the way around and they look great and no rubbing
Old May 22, 2013 | 09:11 PM
In for pics!!!!!!!
Old May 23, 2013 | 10:09 AM
rocketgirl's Avatar
350z 18s on a 4thgen-lugs
Hey I also just picked up a set of 350z 18s off of an '06. I have a 4th gen with stock 15s. Just wondering if anyone has switched these out and would you need longer lugs? Or will it be an easy transition?
Thanks!
Old May 23, 2013 | 10:32 AM
Thanks!
it's fine.
Old May 23, 2013 | 10:41 AM
rocketgirl's Avatar
Cool that's what I figured, thanks.
Old May 23, 2013 | 06:15 PM
aleksey17's Avatar
This is the only pic I took so far with a crappy phone.
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
02nissmax
Sep 5, 2015 01:50 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
