want to buy a lightweight set of wheels, what width won't rub on the struts??
Old 06-19-2013, 05:09 PM
max ride 41's Avatar
as stated, and what spacers can i do?? a local shop said 5mm hub centric spacers with extended lugs only for snugness and fitment quality. thanks
max ride 41 is offline
Old 06-20-2013, 12:20 AM
Fakie J Farkerton's Avatar
Some good info here:
http://forums.maxima.org/4th-generat...installed.html
Fakie J Farkerton is offline
Old 06-20-2013, 07:52 AM
Amerikaner83's Avatar
Amerikaner83 is offline
Old 06-20-2013, 08:44 AM
Dave H.'s Avatar
You looking for 17", 16", etc.?
If you get the proper size and offset wheels, you won't need spacers. More info needed to better help you.
Dave H. is offline
Old 06-20-2013, 09:06 AM
dot dot dot ...
NmexMAX's Avatar
IMO, a lightweight wheel shouldn't exceed 17" diameter either. Get the smallest wheel that accommodates your brakes.
NmexMAX is offline
Old 06-20-2013, 08:55 PM
i want 16" wheels and wanted spacers for my regular wheels as well. i have 17" te wheels now, and i want a lightweight set for summer cause their cheap. any brands to stay away from?? tires i should get?? i like yokohama's best, so anything in a 16" momo or yokohama or bridgestone thats good for summer.
Old 06-20-2013, 09:45 PM
Wanna trade? stock 99SE 16" for your te?
Old 06-20-2013, 10:02 PM
You could get the 15" sawblades off a 4th gen GLE max as well...
Old 06-21-2013, 05:13 AM
i have 15" sawblades allready, i want something other than stock wheels for looks. and, hell no
Old 06-21-2013, 07:15 AM
okay
Old 06-21-2013, 07:31 PM
okay
Old 07-19-2013, 06:04 AM
tigersharkdude's Avatar
R32 wheels (16x8 +30 - 16lbs )
R33 wheels (17x9 +30 [Weight is ~20lbs from what i can find])
tigersharkdude is offline
Old 07-20-2013, 01:37 PM
schmellyfart's Avatar
FD RX7 Wheels seem to fit the bill for you. 16x8 +50 at 16lbs for the reinforced versions. I paid $200 for my set with tires that had 50% tread left. If you search old threads on these wheels everyone says they rub on the struts. Its partially true, the tires will rub on the rear struts while the suspension is completely decompressed. When the car is on the ground under its own weight, there is no rubbing.
I have no doubt that R32 GTR wheels will look great on a 4th gen, a little part of me still wants to pony up the cash for a set of those, but they are not easy to find.
schmellyfart is offline
Old 09-09-2013, 07:57 AM
Aubrey8100's Avatar
I am totally agree with you. Certain 2 facts on this page are unequivocally the best we have all had. You are 100% good here that FD RX7 Wheels seem to fit the bill for you. No doubt R32 GTR wheels will look great on a 4th gen.
Aubrey8100 is offline
homeyclaus
09-03-2015 06:15 PM
twotonezed
08-16-2015 11:41 AM
Team STILLEN
08-10-2015 04:29 PM
RealityCheck
08-05-2015 06:18 AM
Quick Reply: want to buy a lightweight set of wheels, what width won't rub on the struts??
