22"s on a Gen 6?
Old Feb 10, 2015 | 08:27 PM
Streethoboz's Avatar
22"s on a Gen 6?
When I put my 22s on, do I need any bolt on additions for them to fit properly?
Old Feb 10, 2015 | 09:01 PM
Two bottles of NOS should be bolted on because those heavy boat anchors are gonna slow you down...
Old Feb 10, 2015 | 09:33 PM
Do you have any actual help I could use?
Old Feb 10, 2015 | 10:04 PM
Sure, don't do it. You're hurting your acceleration, braking, handling, comfort level...all in the name of looks.
As long as you have the right hub pattern and don't have any ridiculous offsets that would cause rubbing, then no, you don't need anything else to bolt on those boat anchors.
Old Feb 10, 2015 | 10:09 PM
Okay. Thanks for clarifying. I know someone with asixth gen also. Their car came with 22"s and they told me they had some bolt on stuff to make them fit. Do you know if universal five lugs that came from a Ford would fit the sixth gen bolt pattern?
Old Feb 10, 2015 | 10:45 PM
They probably had to buy spacers to clear the brakes. Get the right offset and this will be a non issue.
You'd have to give more information about these Ford universal five lugs for me to determine if they'd fit or not... all I know is your hub bolt pattern is 5-114.30. You should seek out wheels with this bolt pattern.
James92SE
142
Jan 2, 2024 09:23 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
ik95
Sep 16, 2015 08:11 PM
