Set of RARE Mille Miglia EV-S 18" Wheels
Old May 20, 2007 | 09:32 PM
Swisscheese's Avatar
This auction is for a set of practically new Mille Miglia EV-S with Kumho Ecsta ASX 255/35/18s. They are 18x9 with a 45mm Offset and 5x114.3 Bolt Pattern. They have 99.9% of the tire tread remaining and have only been used for 2 days on my Maxima. Basically I bought them and then decided that I did not like them personally and decided to get something else. These wheels stopped being made in 2004, are imported from Italy I believe and CAN NOT BE FOUND(trust me). It took me 4 months to find these and I almost did not post them because of that reason.
Problems:
There is a tiny 1-inch curb rash on two of them, its identical on both and unnoticable unless you put your face to the wheel. No other issues with them.
Shipping is $150 and Local pickup is available if you are in Northwest GA or just like to drive. I will not accept returns on these so make sure they fit. You MUST also insure them. I will pack these up and ship them out same day if it is not too late.
Paypal to bsapatchtrader@gmail.com or Money Order/Cashier's Check Only.
Pictures are on the EBAY Auction at:
http://cm.ebay.com/cm/ck/1065-29296-...iptionANDimage
Old May 20, 2007 | 10:20 PM
Scooobay's Avatar
damn if these were only 19's ...
Old May 21, 2007 | 08:11 AM
They look almost like 19s on the car. Ive got H&R Drop and I think they are the perfect diameter. I spent a long time searching for these, and if I had found 19s along the way I would've bought them, but this was the only set I saw.
Old May 28, 2007 | 03:02 PM
to the top
Old May 28, 2007 | 09:45 PM
VIP Maxima
do they rub
Old May 29, 2007 | 07:31 PM
No, they do not rub, and it is VERY close.
Old May 31, 2007 | 05:58 AM
to the top
Old May 31, 2007 | 01:35 PM
udienow's Avatar
I love these rims, but will 18x9's fit on a 4th gen?
Old Jun 1, 2007 | 05:18 AM
I doubt it, but I do not know.
Old Jun 1, 2007 | 09:55 AM
Fast1one's Avatar
With the offset I would run 5mm spacers all around to make sure you dont rub on the inside in the front and you should be fine...dont run anything bigger than 245/40 ish...Hope you dont have a massive drop either...
Old Jun 1, 2007 | 04:26 PM
Fast1one sounds right. I did not have inside or outside rubbing. I only had them on for about a day though. I also have about 1.5" drop front and back and VERY crappy roads around here. I found no issues.
Old Jun 1, 2007 | 04:28 PM
Someone please pick these up so I can buy some forged wheels =)
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
boomerbrian
Sep 4, 2015 08:25 AM
