NY Musty Smell 4th Gen
Musty Smell 4th Gen
In the past 8 years i have owned quite a few 4 th gen Maximas and 1st gen i30s..7 to be exact....Why do they all have a musty/mildew smell inside,i don't see any leaks inside, Can anybody give me an of where this problem could be coming from....Thanks.....BTW, I will never stop buying these cars regardless...
Edit: Make sure recirculate is OFF.
The directions on the can/Pure Air is the brand I use/ will tell you everything you need to know.
Make sure you have a while to air out your car and vents before you drive. It's pretty strong smelling itself.
Also, make sure your car is "sweating" properly when using your ac, because the drain hole for your evaporator could be clogged with twigs, ect.
Let me know if this helped you.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
