5th Gen How-To/DIY
Old Feb 22, 2009 | 06:57 PM
http://forums.maxima.org/5th-generat...ome-turns.html
http://forums.maxima.org/5th-generat...utch-line.html
http://forums.maxima.org/5th-generat...t-reviews.html
Bookmarked...
More to follow...
3M clear bra installation
Bleeding brakes
Brake pads and rotors selection
Brake pads and rotors replacement
Bump stop (steering) replacement
Dealer decal removal
Fog light replacement (2000-2001)
Fog light bulb replacement (2002-2003)
Fuel filter replacement
http://forums.maxima.org/5th-generat...up-thread.html
HID bulb replacement
Ignition coil testing and replacement
In-cabin microfilter replacement
Manual transmission fluid change
Spark plug/ignition coil replacement (2000-2001)
Spark plug/ignition coil replacement (2002-2003)
Starter replacement
Valve cover replacement
More to follow....
More to follow...
Angel eyes installation
Berk intake installation (Part 1 and Part 2)
Clear front marker installation
Clearing OEM HIDs
DDE wiring to switch
Fog light rewire
HIDs from 2002-2003 installed on 2001-2002
Injen intake installation
iPod/IPhone adapter installation
Motor mount insert installation
O2 simulator installation
Strut/spring decision making
Strut/spring installation
Rear anti-sway bar (RSB) installation
Underdrive pulley (UDP) installation
Y-pipe installation (2002-2003)
Audio System Removal video..
SEmy2K2go's G35 Wheel Restoration
http://forums.maxima.org/tires-wheel...storation.html
DIY Sub Frame Collars:
http://forums.maxima.org/5th-generat...ar-thread.html
Thermostat Replacement:
http://forums.maxima.org/5th-generat...-write-up.html
In cabin filter and blower motor:
http://forums.maxima.org/5th-generat...one-works.html
http://forums.maxima.org/5th-generat...bles-save.html
Old Mar 23, 2011 | 09:32 AM
Puppetmaster's Avatar
Some good ones here from TunerMax:
http://forums.maxima.org/5th-generat...rsion-diy.html
http://forums.maxima.org/5th-generat...g-mod-diy.html
http://forums.maxima.org/5th-generat...ep-please.html
http://forums.maxima.org/5th-generat...drls-done.html
http://forums.maxima.org/5th-generat...guide-diy.html
http://forums.maxima.org/5th-generat...as-please.html
http://forums.maxima.org/5th-generat...gentlemen.html
http://forums.maxima.org/5th-generat...tailights.html
How To Fix DRL (CAN Maximas)
http://forums.maxima.org/5th-generat...eshooting.html
The PROPER way to calculate MPG is:
1. Fill tank completely
2. Reset speedo
3. Drive as far as you feel like, doesn't matter much
4. Re-fill your tank completely
5. Record miles driven between #2 and #4
6. Record Gallons you put in tank at #4
7. Divide Mile reading you got at #5 by Gallon reading you got at #6
EXAMPLE:
1. Fill tank completely done
2. Reset speedo 0 miles
3. Drive as far as you feel like, doesn't matter much 200 miles
4. Re-fill your tank completely done
5. Record miles driven between #2 and #4 200 miles
6. Record Gallons you put in tank at #4 8 Gallons
7. Divide Mile reading you got at #5 by Gallon reading you got at #6 200 Miles / 8 Gallons = 25 MPG
This is why these threads fail, no one has a bloody clue how to calculate their mileage, and everyone throws out numbers.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
220k+ A32
Sep 23, 2015 03:38 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
