1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Easy 12 second pass 5.5 gen maxima
Old 11-29-2013, 07:42 AM
02Lightblue maxii's Avatar
well now that i ran consistent 12 second passes, im wondering now how much lower into the 12's will i get? I've got a few parts to put on and next time i go i will try to work on the aerodynamics of the car.
-Cosmo Racing Underdrive Pulley
-Port and polished LIM + SSIM UIM + elbow cutout
-REAL SLICKS on 15" rims
-strip a few more things out the car, rear bumper support, dashboard, etc. considering taking out the sunroof assembly and somehow putting in a piece of plexiglass.(still looking into it)
-Retune Greddy e-mange BLUE to SUPER agressive tune
-**OR** considering buying a Greddy e-manage ULTIMATE from a buddy for 300$ with a universal harness and all the books and wiring diagrams.ANY THOUGHTS?
-considering buying the NWP 3.5" TB (full kit)(360+shipping) duno if its worth it tho.
-finally getting a new NWP Upper-lowermanifold spacer, as im currently running no spacer just hi-temp silicone.
02Lightblue maxii is offline
Old 11-29-2013, 12:06 PM
Turbo 3.5
t6378tp's Avatar
I would just do the pulley, slicks and weight reduction for now. I wouldn't bother with a ssim till you get a EU and extend the rev limiter.
You'll be shocked at the gains from 24.5inch slicks alone will net you, also strap down the front end if u don't have coilovers
t6378tp is offline
Old 11-29-2013, 06:41 PM
krazy6's Avatar
I agree!
You could could also take a sheet of aluminum, cut it to fit, and block off the sunroof. I would just focus on getting the 24.5 slicks on there and taking more weight out of it.
Have you thought about cutting out the metal on the doors and putting lexan windows on? That would save a ton of weight.
krazy6 is offline
Old 11-29-2013, 10:32 PM
tbh wanted to keep the power windows they're a nice feature to have, atleast for the front ones
Old 12-01-2013, 10:19 AM
george__'s Avatar
@OP
Nice car!
george__ is offline
Old 12-01-2013, 09:09 PM
Originally Posted by george__
@OP
Nice car!
thanks alot! I really appreciate the maxima community support
Originally Posted by krazy6
I agree!
im taking the sunroof assembly out this spring, aswell as cutting out the door panels and the rear deck lid. A buddy of mine has a pair of 22x8x15" slicks he said he would let me use for a few passes. Im really tempted to buy those 27x8x15's hes just askin for 80$ for em, wanted to buy em and try em out to see how much traction they'll have. I realistically want minimal spin
just picked up a pair of Mickey Thompson ET DRAG SLICKS 24.5/8-15, CANT wait to try these puppies out! FINALLY gonna have <2.000 60ft.
Old 12-14-2013, 11:18 PM
krazy6's Avatar
Perfect! You made the right choice right there. That is the exact tire you want.
Should be some 1.7 60fts in your future!
krazy6 is offline
Old 12-16-2013, 05:41 AM
another buddy of mine is selling a pair of 22-8-15's dont know if i should try those out too, but anyhow, i really hope to get under 1.8 60FT, < 12.499...soon to come hopefully!
I need to weigh the slicks and see what the rim and tire combo will weigh, 1 rim alone is 13.8 lbs hype
Old 12-16-2013, 11:18 AM
ABIGBRAIN's Avatar
Those 22's are 14 lbs. apiece. The 24.5's are a little bit heavier.
ABIGBRAIN is offline
Old 12-16-2013, 08:55 PM
krazy6's Avatar
I think you'll find that the 24.5's will work better with your gearing.
krazy6 is offline
Old 12-16-2013, 09:16 PM
yeah i actually compared them side by side , i think 22 would be a bit small. if i dont manage to hook up for some reason on these im gonna consider like 26-27, but i HIGHLY doubt im gonna have a traction issue now, these slicks are unbelievably slicky, and soft.
Old 12-17-2013, 04:55 AM
TriniMax03's Avatar
Are you on the stock axles? How are you launching? Would like to know just so I have an idea when I take my maxi to the track
TriniMax03 is offline
Old 12-17-2013, 08:58 PM
yeah stock axles, they manage to take a beating, i found a good launch on either street tires or drag radials is about 2-2250 rpm, not sure about slicks, will have to find out this summer
Old 12-17-2013, 10:40 PM
krazy6's Avatar
Yeah, the stock axles are pretty beefy. They took my 6500 "slip dump" launches with no problems.
krazy6 is offline
Old 12-18-2013, 04:52 AM
TriniMax03's Avatar
Wow. I'd love to know how they hold up to the slicks though. I knew they were strong but this is good info. Thinking back now I haven't heard of anyone snapping one of these maxima axles. I know Ramnas on here is making 411 hp and I never heard him mention changing axles
Old 12-18-2013, 08:22 PM
krazy6's Avatar
I was on a Mickey Thompson ET street which is practically like a slick.
krazy6 is offline
Old 12-19-2013, 05:10 AM
TriniMax03's Avatar
So I should be fine taking my car to the track with some Drag Radials on it with a 3000 rpm launch and not worrying about my axles. Hoping for a low 14 full weight
Old 12-19-2013, 07:47 PM
what mods? cause i ran 14.1 @ 98 ish when i had it at full weight. i had NWP BOP gutted pre cats, test pipe, 2.5" catback NWP 5 piece spacer
Old 12-24-2013, 03:12 AM
TriniMax03's Avatar
I have OBX v2 headers, 2.5 inch Megan OE -RS Catback, injen intake, NWP Block off plate, NWP 5 piece spacers, Nwp torque link, 350z clutch. Planing on doing 4 inch integrated MAF intake next week with a VAFC tune, and maybe jwt flywheel before i take it in the track
Old 12-24-2013, 08:44 AM
honestly the track comes down to driver...it came shave up to a full second on a 1/4 mile (usually more realistically between .001-.500...which can either make it a low 14 sec car or high 13 sec car. Best recommendation would be to practice your quick shifts, pump the back tires up to about 45psi, front 25-30psi, launch around 2k-2200slightly bouncing the revs, when the tree drops..giv'r. Let rev limiter bounce once MAX twice and immediatly shift into second, make sure you go to the top of all gears without overrevving. with those mods you should honestly be able to do a high 13 pass EASY. when i did 14.1 @98 i only had: NWP 5 piece spacer(missing 1 piece), NWP B.O.P, Injen intake short-ram,Stock headers, Gutted Precats, Warpspeed y pipe, a custom 2.5" catback that was TERRIBLY done and timing advanced at the dealer to 17*. stock flywheel, exedy oem replacement clutch. FULL WEIGHT
forgot to mention to it was at a very badly prepped track and quite bumpy after you get into 3rd get lol. Ghetto french canadian tracks
Old 12-24-2013, 01:21 PM
TriniMax03's Avatar
Thanks for the tips. It'll be my first time on the track I'm only 19 so of corse I'm going to screw up a few things but I can haul *** through the gears. I'll practice the 2-2.2 k launch, I've been doing 3k launches feathering off the line. I'll see what happens with a 2k.
Old 12-27-2013, 09:53 AM
just got a change to weigh the rim & tire mounted and balanced, 27.6 lbs. hopefully thats a little lighter than my other wheels,it all adds up! cant wait to try em out!
Old 12-28-2013, 12:06 PM
krazy6's Avatar
Nice, that's light!
krazy6 is offline
Old 12-29-2013, 01:51 PM
schmellyfart's Avatar
Perhaps I missed it earlier in the thread, what wheel/tire? Slicks on 15s?
schmellyfart is offline
Old 12-29-2013, 02:03 PM
ABIGBRAIN's Avatar
From his other thread
just wondering how to get maximum grip out of them. Ive never used a REAL drag slick before , such soft rubber its insane! Im assuming im gonna need to rev alot higher to get them to spin? any tips on tire pressure and burnout time etc? They are Mickey Thompson 24.5-8-15 mounted on Drag Dr-21 wheels 15x7 et 40.
Old 12-30-2013, 12:27 PM
found a video of my 12.8 pass!
Old 12-30-2013, 05:23 PM
Thanks!
Old 01-03-2014, 07:42 AM
VQtHuRtY's Avatar
What mods are currently done to the car?
VQtHuRtY is offline
Old 01-04-2014, 09:00 AM
http://forums.maxima.org/5th-generat...questions.html
read up this earlier thread i posted, you can also follow me on Instagram Ruskii92 i have a FULL mod list posted there, aswell as future mods
Old 01-07-2014, 09:16 PM
george__'s Avatar
how is the tuning going?
george__ is offline
Old 01-08-2014, 09:03 PM
havent started yet, i still need to wire in the EMU once the snow melts, or alteast gets a bit warmer. is there anywhere where i can find a base tune to work with thats agressive?
Old 01-10-2014, 05:03 PM
george__'s Avatar
I doubt it
george__ is offline
Finkle
09-27-2015 09:53 PM
tcb_02_max
09-23-2015 06:18 AM
tcb_02_max
09-11-2015 12:23 PM
MaxStock
08-12-2015 08:33 AM
Quick Reply: Easy 12 second pass 5.5 gen maxima
