The acceleration/shifting problem
Old 04-15-2008, 09:29 AM
  #121
White_Shadow
rmdl51's Avatar
Very nice pictures man! Thanks! that is becoming easier to understand, however you are right, I need to look at the manual valve arm, maybe I should try to adjust it myself again because last time the "mechanic" adjust it and he said it was fine but I never saw him move the shifter from inside the car to neutral. Thanks for the A-B-C explanation wiking, (waiting for C)
Wiking, what do you think about measures on TCU-TPS?
Currently Active Users Viewing This Thread: 3 (3 members and 0 guests)
capedcadaver , rmdl51 , Wiking
rmdl51 is offline
Old 04-15-2008, 10:32 AM
  #122
Wiking's Avatar
Originally Posted by capedcadaver
what will C represent?....
Yes, whole world is watching this very important Inhibitor...
You C its in the pic u will pick for me = All three have to be aligned with a 5mm drill bit with the Inhibitor sw case?
This attachment screw/bolt is 10mm? No Screwdriver needed, a 10 socket is better, small ratchet wrench (or whatever its called)
Wiking is offline
Old 04-15-2008, 10:44 AM
  #123
Wiking's Avatar
Originally Posted by rmdl51
... an 8mm socket I can unscrew ... about inhib sw, what does it r... distro cap shows a little bit of black stuff l... from 1.085v to 3.073v is that healty? ... to measure again when I'm a little bit more rested....
Is it 8mm? ...I say socket is better. (No experience on this location.)
Inhibitor Switch is just a switch-pack. Connects various points depending on how its positioned: one is connected, represents P, another ... N, then D, 2, 1 ...
Distributor cap tends to crack, even new may be bad. Check http://www.cardomain.com/ride/748507/12
TPS Sounds good. The top measurement will be that 8k again - after good night sleep...
Wiking is offline
Old 04-15-2008, 11:30 PM
  #124
Wiking's Avatar
cape... ...gear lever pics???... cant find.
Question: did u have gear lock bypass ON when the A/T disconnected?
Wiking is offline
Old 04-15-2008, 11:33 PM
  #125
Call me Wookiee Goldberg
CapedCadaver's Avatar
i'll upload the pictures of the manual valve arm in the morning. I sold my shifter to another org member already to match his new leather seats in his GXE, so i can't take any pics of the shifter itself. but i took a video of how to remove the thing, as well as how to align it. but i hate how my voice sounds when recorded so i didn't talk during it. i sound so... gay when i talk.
CapedCadaver is offline
Old 04-16-2008, 06:35 AM
  #126
Wiking's Avatar
...gear lever pics...
ok. needed 'some acro bat ics ... anyways here they come, text for adjustment can be read /commented at
http://www.cardomain.com/ride/748507/15
Wiking is offline
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
hcarter1112
42
07-18-2022 03:35 PM
gavin68
09-18-2021 12:36 PM
HerpDerp1919
09-29-2015 02:02 PM
Quick Reply: The acceleration/shifting problem
