Is it dangerous to drive with a bad wheel bearing?
Old 05-23-2009, 07:43 AM
  #41
petro2342's Avatar
Originally Posted by s0mbra
well i think i have a bad wheel bearing... on the driver side front wheel there is a whining noise, kinda like whistling sound, cant really explain it. any one have any ideas, i have no wheel vibration, no uneven brake pads, just that really annoying sound. u guys think its the wheel bearing?
Since the weathers been really nice lately I was cruising down a hill in neutral and has I passed parked cars I heard a whining sound as well. As I slowed down it was pretty loud and got quiet after I stopped. I too believe its the wheel bearing and I asked my friend about this. He said I could still "save" it by putting grease in there as it could of dried up.
petro2342 is offline
Old 05-23-2009, 08:53 AM
  #42
KH3 by popular demand
maxgtr2000's Avatar
I couldn't feel any play when mine went bad, it was just a low screeching noise. I couldn't tell if it is was metal grinding or rubber squeaking. i thought maybe my cv boot was rubbing against itself or something. Mastercater7 help me change it out, I got the bearing off ebay, seals from the dealer, (verified the correct part number because it is the same bearing as some other nissans) took the knuckle off, took it to Sears with the bearing and got it pressed for $40. I wouldn't recommend Sears but they do it if they have the machine. That's a good price posted in post 15 to get all that done. Turbo max+bad wheel bearings= fail.
maxgtr2000 is offline
Old 05-23-2009, 02:58 PM
  #43
99 Limited Se's Avatar
so how much is it to replace the hub and bearing? like price range? and is it a do it your self? or have profeesional do it?
99 Limited Se is offline
Old 05-23-2009, 07:45 PM
  #44
anovib's Avatar
my front wheel bearings were $550 when pep boys did them.
anovib is offline
Old 05-23-2009, 11:53 PM
  #45
ThurzNite's Avatar
$50 Wheel bearing, 2yr warranty
$20 to let someone use a hydraulic press to press the old bearing out of the hub. If you drove on the bad bearing for an extended time, you might need a new hub, and that's about $80 from the dealer.
http://www.motorvate.ca/mvp.php/704
Dr J
ThurzNite is offline
Old 05-24-2009, 12:54 AM
  #46
jinshiyang's Avatar
But I have one more thing to say: do NOT take it on a high speed long run, because bad bearings get very much worse really quickly at high speed thread insert helicoil
jinshiyang is offline
Lakersallday24
03-20-2024 11:22 AM
boomerbrian
11-08-2015 05:10 PM
Flores94
08-11-2015 12:53 PM
FanaticMadMax
08-10-2015 08:55 PM
Quick Reply: Is it dangerous to drive with a bad wheel bearing?
