96 MAXIMA SAME FUSE KEEPS BLOWING AND CAR WONT START
Old 05-24-2012, 01:26 PM
rzavala10's Avatar
HEY I GOT AN AUTOMATIC 96 MAXIMA MY FUSE KEEPS CONSTANTLY BLOWING AND ITS THE SAME ONE.I THINK I SHOULD CHANGE THE FUSE BOX BUT NOT SURE THIS IS THE PROB BUT I KNOW ITS A SHORT CIRCUIT. IT WILL BLOW THE FUSE THEN THE CAR WONT START UNTIL I CHANGE IT, IT BLEW SIX FUSES IN A ROW EVERY TIME I CHANGED IT ONE TIME. IT WOULD MAKE A BIG SPARK. IT IS ON THE FUSE BOX INSIDE IT IN THE MIDDLE ROW OF FUSES THE SEVENTH ONE FROM THE BOTTOM UP IT SAY BAT/7.5/INT ILL.. LET ME KNOW YOUR IDEAS ON HOW TO FIX THIS PROBLEM THANKS
rzavala10 is offline
Old 05-24-2012, 01:59 PM
Amerikaner83's Avatar
Well INT ILL MEANS ITS THE CIRCUIT FOR THE INTEROIR ILLUMINATION. YOUR CAR SHOULD START FINE REGARDLESS.
DID YOU REPLACE A BULB RECENTLY INSIDE THE CAR?
TRY STARTING THE CAR WITH THE HEADLIGHTS OFF. THE FUSE WILL NOT BLOW. TURN ON THE HEADLIGHTS BLOWS THE FUSE, YES? ITS SOMETHING IN THE CIRCUIT OF THE INTERIOR LIGHTS.
Amerikaner83 is offline
Old 05-24-2012, 02:19 PM
asand1's Avatar
IT IS MOST LIKELY THE DOME LIGHT OR ANOTHER BULB INSTALLED INCORRECTLY. REMOVE BULBS UNTIL THE BROBLEM GOES AWAY. IT COULD ALSO BE A SHORTED WIRE, BUT NOT AS LIKELY. WHY ON EARTH WOULD YOU REPLACE THE FUSE BOX RATHER THAN TROUBLESHOOT, STARTING WITH THE LOADS (LIGHTS) AND WORKING BACK.
http://www.bing.com/videos/search?q=...03A2B2&first=0
asand1 is offline
Old 05-24-2012, 03:24 PM
KH3 by popular demand
maxgtr2000's Avatar
FUSES BLOW BECAUSE POSITIVE IS TOUCHING NEGATIVE. FOR EXAMPLE IF THERE IS WATER SOMEHOW GETTING IN YOUR DOOR, THE LOWER DOOR LIGHT WILL CAUSE THE SHORT. DO NOT PUT A HIGHER RATED FUSE IN THE HOLDER, THE FUSE IS FOR YOUR PROTECTION.
maxgtr2000 is offline
Old 05-24-2012, 05:56 PM
Trini Boom's Avatar
OP IS JUST BEING IMPATIENT AND SHOULD TAKE YOUR TIME AND RECALL THE LAST THING YOU DID OR TOUCH. IF YOU DIDN'T TOUCH ANYTHING, WAS THERE A RAINSTORM RECENTLY?
(YOU GUYS ARE WRONG FOR THE CAPS BUT DECIDED TO KEEP IT CONSISTENT! )
Trini Boom is offline
Old 05-24-2012, 09:09 PM
NOT WRONG FOR DOING CAPS, JUST KEEPIN' IT CONSITENT WITH THE OP MANG, Y'KNOW? IF IT'D BE ALL LOWERCASE NORMALZ N SHYT IT'D BE ALL LIKE "SAY WAAA? DIS SHYT"
Old 05-25-2012, 08:03 AM
pavelsmax's Avatar
pavelsmax is offline
Old 05-25-2012, 08:54 AM
SNIFFERPIVOTS's Avatar
DOES YOUR TRUNK LEAK?? CHECK FOR MOISTURE AROUND THE REAR DECK ILLUMINATION RECEPTICAL
SNIFFERPIVOTS is offline
Old 05-25-2012, 09:27 AM
:MRGONE:
ChrisMan287 is offline
Old 05-26-2012, 12:19 PM
rzavala10's Avatar
thanks for the help guys well the fuse usually blows when iv been driving it for a while i just remembered that there was always a rattling noise in the inside light that you could turn on right on top of the driver seat maybe every time the light bulb would make contact it would short circuit but that same fuse would blow out and the car would not start until i changed it
Old 05-26-2012, 12:20 PM
rzavala10's Avatar
the bulb was loose so i just removed it
Old 05-26-2012, 12:22 PM
rzavala10's Avatar
u were right the dome light closer to the drivers side was loose but wouldnt turn on it was just rattling in there hopefully removing it fixed the problem but how wierd that that would cause the fuse to blow and not let the car start
Old 05-26-2012, 12:24 PM
rzavala10's Avatar
i dont know why the car didnt start, but it didnt until i replaced the fuse its on crack lol
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
acw
08-13-2015 12:50 AM
kirkhilles
08-08-2015 10:53 AM
acw
08-07-2015 04:20 PM
Quick Reply: 96 MAXIMA SAME FUSE KEEPS BLOWING AND CAR WONT START
