Speedometer
Speedometer
Hi all
Just purchased a 1999 max qx which is nice! I have a problem with the speedo,sometimes it works and sometimes the needles either go all the way to the top or go all way to the bottom and the mileage screen goes blank then after a while it goes back to normal! Can this problem be fixed?
Hi all
Your problem is either the gauge cluster itself (solder points), the wiring leading to and from the gauge cluster, or the vehicle speed senor (located on top of the transmission), or the wires leading to and from that.
Your easiest and cheapest route is to buy a new vss. They're cheap and easy to replace. There are a couple write ups here on the org. If that doesn't help and your not good with soldering, then either buy a gauge cluster from here in the classifieds section or go pull one from a local junkyard (also easy to replace but more involved than vss)
Just change your cluster, its pretty easy!! Couple of screws out of gauge cluster gourmet i think 2, then bam your finger tips are at the cluster. Then pull those screws out, tilt top of guages forward to remove plug in and done. Then just install your new/old bought one and go on. I tried re-soldering mine didnt work or i failed either one lol
Oldshadetreeguy
10-01-2016 05:00 PM
Frank Fontaine
09-28-2016 09:52 AM
TRevion Cookin
09-21-2016 02:16 PM
