Should I use antiseize on my spark plugs when I replace them?
Old 02-28-2003, 02:01 PM
y2kse's Avatar
Most threads on spark plugs designed for aluminum-head applications are precoated to reduce the risk of thread damage. If you’re in the habit of applying a drop of antiseize compound to the plug threads before they go in for added insurance, you might want to reconsider this practice. One vehicle manufacturer warns against this practice because antiseize acts like a lubricant and may allow the plugs to be overtightened — which can damage the threads. Their advice is to reduce the tightening torque on the plugs by 40% if you decide to use antiseize on the threads.
[Source: http://www.babcox.com/editorial/ic/ic69940.htm]
y2kse is offline
Old 02-28-2003, 02:03 PM
I'm needing a caw
Jeff92se's Avatar
Yes. Be careful not to get it on the plug tips. Threads only. In 60k, you will be thanking me very much
It sure beats having a plug seize in the head or breaking the plug off when trying to get the plug out(after it's been cooking in your engine for 4-5 years)
I've used anti-seize for years and years and years etc.... I don't even use a torque wrench(but I guess rookies should). Common sense rules here ya know?
Jeff92se is offline
Old 02-28-2003, 02:36 PM
DAVEB's Avatar
Re: Should I use antiseize on my spark plugs when I replace them?
I say heck yes! I've used it on plugs for years with great success. Also, check your PM.
DAVEB is offline
Old 03-01-2003, 01:47 PM
griffy2k2max's Avatar
Definitely use it, just put some on the first 2-3 threads, you'll thank yourself many miles from now when it's time to change them. just don't allow any to fall into the engine block
griffy2k2max is offline
Old 03-01-2003, 03:59 PM
Max_Gator's Avatar
absolutely.
Max_Gator is offline
Slamrod
09-03-2015 07:38 PM
Maxboy23
08-21-2015 11:02 AM
Turbobink
08-15-2015 07:20 AM
1992maximase30
08-05-2015 09:27 PM
maxima297
08-03-2015 12:50 PM
Quick Reply: Should I use antiseize on my spark plugs when I replace them?
