transmission oil leaking?
Old 09-21-2007, 09:03 PM
jasonmax's Avatar
Transmission oil leaking?
I brought my 2002 Maxima GLE two days ago.
Today, when I made a U-Turn at an intersection, I heard tire squealing, but I didn't step on the gas pedal very heavily just like normal driving. Nothing happend, so I pulled over and checked the car. I found the bottom of the transemission was greasy. Is it possible to fix it, and how much it will be?
btw. what is the phenomenon of DIFF failure?
It was really pissing me off that somebody threw his door on my car...i got two small dents on the right side of my car...
jasonmax is offline
Old 09-21-2007, 10:55 PM
wat
AceofSpds's Avatar
pictures and much more description is needed
AceofSpds is offline
Old 09-22-2007, 02:23 PM
jasonmax's Avatar
how do you think?
jasonmax is offline
Old 09-22-2007, 02:28 PM
Cletus
SoonerFan's Avatar
there is oil all over the bottom of your engine...you sure its from the tranny?
SoonerFan is offline
Old 09-22-2007, 02:32 PM
808MAX-SPEC's Avatar
Check you power steering fluid reservoir. Some cars use transmission fluid for power steering. If it's lower than normal, your power steering pump may have gone bad. But if nothing is wrong then it has to be your transmission.
808MAX-SPEC is offline
Old 09-22-2007, 02:44 PM
Cletus
SoonerFan's Avatar
the power steering pump is on the complete other side of the engine
jasonmax's Avatar
it's driver side, so i think it's the tranny
jasonmax is offline
Old 09-22-2007, 02:45 PM
jasonmax's Avatar
which side?
jasonmax is offline
Old 09-22-2007, 02:53 PM
Cletus
SoonerFan's Avatar
tranny - drivers side
power steering pump - passenger side
Old 09-22-2007, 03:11 PM
jasonmax's Avatar
I know that....
I checked my tranny again and found out there is a pipe between the tranny and the radiator. At the tranny side is greasy..
jasonmax is offline
Old 09-22-2007, 03:16 PM
wyche89's Avatar
btw.. check your tire pressure.. that might take care of the squealing
wyche89 is offline
Old 09-22-2007, 03:23 PM
jasonmax's Avatar
more photos, more details
jasonmax is offline
Old 09-22-2007, 03:25 PM
Cletus
SoonerFan's Avatar
that looks way to high on the tranny to be coming from where the pan connects or from the cooling connection
Old 09-22-2007, 03:27 PM
wyche89's Avatar
from the pics it looks like the fluid might be kinda dried up... since you just bought the car 2 days ago, it might be from a leak that the car had, but they fixed it and just didnt wipe off the parts
touch the parts and see if you feel moisture
wyche89 is offline
Old 09-22-2007, 03:45 PM
jasonmax's Avatar
I think it's moisture
Who knows what this is?
jasonmax is offline
Old 09-22-2007, 04:27 PM
jasonmax's Avatar
anybody has an idea?
jasonmax is offline
Old 09-22-2007, 05:22 PM
wat
AceofSpds's Avatar
Its part of the trans, it looks to me like there was some other problem like a dipstick wasnt in its place and fluid shot up everywhere. Get some degreaser and clean it off, and then keeep an eye out for more stains.
Old 09-22-2007, 06:21 PM
jasonmax's Avatar
I'll try this tomorrow..
jasonmax is offline
03-12-2020 12:06 AM
The Wizard
24
10-01-2015 08:47 PM
RWCreative
09-21-2015 11:01 AM
seesole
09-14-2015 12:38 PM
ag90fox
09-09-2015 12:22 PM
Quick Reply: transmission oil leaking?
