car will not start
car will not start
2000 maxima will not turn over. For some reason i dont think the injectors are spraying the gas. I have fuel pressure, spark, check engine light is not on, security light is not flashing, i have power at the injectors, and i can start the car with starting fluid. pulled a couple plugs and they seem to look pretty dry. how can i check to see if gas is making it to the injectors?
Yea, i was thinking that. A lot of the times the aluminum between the sensor and trans swells up due to road salt and actually pushes the sensor out a little. Maybe unbolt it (becareful not to cut the bolt) and clean the surface and put the sensor back in.
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MAXSE5SPD
08-23-2015 12:06 PM
MaximaDrvr
08-19-2015 08:20 PM
