re starting issues
Old 09-10-2015, 07:03 AM
gustavison's Avatar
re starting issues
Hi all, new member here. I have an 06 that will not re start after its shut off. I've had it a good shop, they have checked all the obvious (codes, fuel pressure, live data etc), scoped the crank and both cam sensors, scoped the coil drivers and injector drivers. When in the failed mode the injectors are not being energized but the coils are. There are no NATS codes, and the security light remains off while cranking. They suspect either a stretched timing chain causing cam crank sync issues, or defective ecu. Suggestions?
gustavison is offline
Old 09-10-2015, 09:24 AM
zillafreak's Avatar
Does it start once it cools down?
zillafreak is offline
Old 09-10-2015, 09:53 AM
gustavison's Avatar
yes
Old 09-10-2015, 12:23 PM
gustavison's Avatar
Anyone??????????
Old 10-04-2015, 06:50 PM
jlm246810's Avatar
it just happened to me and the mechanic said that it was the timing chain, just waiting to get more money to replace it
jlm246810 is offline
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
Maxima30
09-07-2015 06:13 PM
trungg86
09-04-2015 04:58 AM
Quick Reply: re starting issues
